New pistons?
New pistons?
I just read in another thread that Russ Pottenger is developing a new piston with Racetec. Can you provide more info on this Russ? I will be ordering pistons soon and would love to hear of any new options.
Jason
Jason
Re: New pistons?
Hi Jason,
RaceTec will be working with me on several changes and options
Incorporated in the current piston design.
The most notable and obvious change is that we will no longer be restricted to using a symmetrical
reverse chamber dish piston. Although the current pattern is based off of my ported 7120 head chamber,
all stock untouched cumbustion chamber heads will benefit.
Reverse dome volumes up to 28cc shouldn't be a problem.
A floating pin option will also be available. I can machine and install AB bushings in customers rods
or sell you bushed rods outright.
I'll be carrying a fair amount of in inventory, but the usual 3 to 4 week applies to customs at
no additional costs.
Russ
Russ
Re: New pistons?
Any chance of a thicker head so a larger reverse dome than 28 cc would be possible? Thinking supercharged/turbocharge pistons.
Re: New pistons?
The limitation is the crown thickness in the forging.johnj92131 wrote:Any chance of a thicker head so a larger reverse dome than 28 cc would be possible? Thinking supercharged/turbocharge pistons.
A full circular dish would be acceptable in a supercharged/turbo.
That would help in gaining additional volume as long as the crown
thickness isn't compromised. Using a aftermarket connecting rod like
a Scat that doesn't have a balance pad which requires additional clearanceing
would also help.
My 7120 chambers typically come out to 62cc and can go to 65cc
I'm guessing I can get the Edelbrock to 60
Hope that helps
Re: New pistons?
So they'll be available soon? What about price, any Idea?
Jason
Jason
Re: New pistons?
Pistons are about 3 weeks out now.
In about 2 months orders will be filled in 5 business days.
Depending on options they will run $550.00 to $575.00 a set.
Further discounts if ordered in a engine kit.
Russ
Russ
- Vehicle Model: xj
Re: New pistons?
Rings and pins included?
Re: New pistons?
Pistons and wrist pins are included.jeepxj3 wrote:Rings and pins included?
Rings are available at a additional cost.
- IH 392
Re: New pistons?
STD. or Metric ring package?
Re: New pistons?
Ring package of your choice at no additional cost.IH 392 wrote:STD. or Metric ring package?
- Vehicle Model: xj
Re: New pistons?
What pin heights?
Only for strokers? or also for stock 4.0L? Overbore? 0.030"? 0.060"?
Re: New pistons?
I can do a compression height to your specification at no additional cost.
My stocking shelf pistons will have a compression height of 1.390.
With a unmachined deck and rods, that should put you around a zero deck
with a 3.876 stroke 258/4.2 crankshaft.
That way you have the option of leavin the deck alone, or do what I do and
machine .010 off the deck and have the option of a .043 or .051 head gasket
to use based on how short the rods get after sizing, and/or application.
Russ
Russ
Re: New pistons?
Hey there Russ, is a flat top piston an option?
Re: New pistons?
No problem, and less expensive.BADASYJ wrote:Hey there Russ, is a flat top piston an option?
PM me and will give you some pricing and additional information.
Thanks,
Russ
[email protected]
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
