A/c Bracket bearing
Frankenstien
I think I'll order a "tab"
Vehicle Year: 1972
Vehicle Model: Cj5
A/c Bracket bearing
Post by Frankenstien »
I did the search with no results but has anybody found the exact bearing part number for this bearing on this a/c bracket yet?
Thought I found one on the bay under water pump bearing as that is what the web seems to point to but really unsure. Supposed to fit 95 4.0 jeep engine a/c mounting support bracket passenger side near valve cover.
This is a pic of the OEM bracket...
eBay item number:
281796225904
Thanks! Best,
:cheers:
Frankenstein
rammit11
Vehicle Model: cherokee
Re: A/c Bracket bearing
Post by rammit11 »
Am I correct in that this is the bearing where the idler pulley is located? I did mine on a 98 and that bearing is considered a water pump bearing. I removed mine and had the local bearing house and had them match it up. The catch is that the bearing needs to have the shafts cut to length. I hope this gives you a little better idea on what you are looking for.
Frankenstien
Vehicle Year: 1972
Vehicle Model: Cj5
Any other ideas out there for bearing manufacture and part numbers?
Thanks!
:cheers:
Frankenstein
jasonb
Post by jasonb »
NSK 885586 is the part I have noted from another forum. I intend to get one but haven't yet so I don't have first hand knowledge that it's the right one. I was planning on pressing mine out first and verifying the dimensions before I buy.
Jason
dott
Post by dott »
You can figure out the dimensions of the bearing (inner race, outer race and thickness) by looking up the part number on the bearing, if that helps...
jasonb
Post by jasonb »
I went ahead and pressed one out so I could measure and order one. I can't find the dimensions for the 885586, but all the pictures I see look long without cutting. This catalog is very helpful: http://rolling.hu/pdf/FAG_waterpump_catalogue.pdf
My bearing matches the FAG W2456, which crosses to an NSK 885162 and is also in the catalog for some Jeeps. Mine is a 96 and I know the a/c bracket changed through the years, the bearing may have changed too so it may not apply to your year.
Jason
Frankenstien
Vehicle Year: 1972
Vehicle Model: Cj5
Thanks!
:cheers:
Frankenstein
