What would my quench height be ?
Horsepower ballpark ? I'm thinking 250 +/-
Pistons I think will be the sealed power 677 60 over.
I figure with a basic build my AMC eagle sx4 is going to hall ass. Thanks and Merry Christmas to all
I'd recommend that you go with the modified poor man's stroker build:amceaglesx4 wrote:I decided with my 4.7 stroker to go basically the poor man setup with the 258 crank , rods and oversized pistons. What I'm thinking is just using the stock 99 cam with a 43 head gasket. From what I read I should be somewhere in the 9.1 compression ratio are. So a few basic questions if anybody knows by chance. Also most likely the head and block will be planed just for straightness purposes. So...
What would my quench height be ?![]()
Original "poor man's" stroker
Same as above but with Jeep 4.2L 5.875" rods and Sealed Power 677CP +0.020" bore pistons. Unfortunately the high 0.088" quench height makes this combination more sensitive to detonation if the fuel quality is poor. This deficiency is rectified with the use of longer 4.0L connecting rods and custom forged pistons. This modified version is a great stroker build for a mild supercharger/turbo application with up to 6psi of boost. The 4.0L connecting rod/forged piston combination offers less reciprocating mass than the 4.2L rod/677P piston combination, thereby giving this engine a potentially higher rpm capability than the original "poor man's" stroker. The tight quench also allows this engine to run on 87 octane fuel in naturally-aspirated form.
Don't even bother.amceaglesx4 wrote:If I stick with the 258 rods and the 677 pistons 60 over how can I bring the quench height down from .088 to the .043 ???
This.jsawduste wrote:Use the 4.0 sized rods and a set of pistons from Russ, Bulltear or Diamond/Hesco.
Custom pistons at $450 will cost you less than the total cost of a set of 258 rods (unless you already have those for free), 677CP pistons, shaving the block deck, and buying a set of shorter pushrods ('cause you've shortened the deck height).amceaglesx4 wrote:See this is why I get angry. Poor man !!! I don't want to drop 4-500$ on custom pistons and change everything around. Its bad enough I can't buy a new crank for $200. Now its called a stroker crank for $400+.
Your math is correct.amceaglesx4 wrote:Doing a little more research and found out the 258 crank, rods and stock pistons ( 677 from Sealed power ) and that's basically it. Level the block and head looks like a 80 +/- quench height. With a 43 head gasket , little decking brings down quench height and compression is raised. I think I read 10 thousandths off equals .2 in compression. Don't quote me on that.
You obviously didn't understand what I quoted in an earlier post so let me explain the reasoning to you again.amceaglesx4 wrote:I'm still not getting why .50 needs to be shaved off the block or custom dished pistons need to be used. I get there a lot of ways of making strokers but it seems like so much effort and peoples dollars are being wasted to custom make something that doesn't need to be fully custom.
jsawduste wrote:Suggest you forget this whole stroker thing and buy a crate engine from Summit Racing.
Then your only decision will be polished or painted valve covers. It might be a struggle to decide but you'll be OK.
Users browsing this forum: Amazon [Bot], Bing [Bot], Semrush [Bot] and 1 guest
