OBII engine management ?
Zorm
Vehicle Year: 1983
Post by Zorm »
anyone have their stroker using the OBII system? Right now I have the OBI system from a 92 Cherokee. May be moving to the OBII system because I might be putting in a turbo after I get the engine running correctly. If you are using the OBII system 95 and newer I think, did you need to do anything extra to run the engine or even to tune it?
thanks
Re: OBII engine management ?
Even if you go turbo, you could stick to your OBD1 ECU and use a 2-bar MAP sensor together with a programmable piggyback computer such as the Split Second FTC.
