Just curious... 4.2 to a 4.7 stroker
amceaglesx4
- Vehicle Year: 1981
- Vehicle Make: amc
- Vehicle Model: eaglesx4
Curiosity I guess. Is it possible to basically make the 4.2 into the 4.0-4.7 stroker ? Is it basically just taking a shit ton off the block ?
Re: Just curious... 4.2 to a 4.7 stroker
The only company that I knew of that had stroker cranks for the 258 engine was Flatlander Racing and they went out of business 3 months ago.
If you want to build a stroker, your only option is to start with a complete 4.0L engine and use the crank from your 258.
jeepxj3
- Vehicle Model: xj
Cheromaniac wrote:Flatlander Racing and they went out of business 3 months ago.
amceaglesx4
- Vehicle Make: amc
No. LMAO... just curious. I thought since it was basically the same block you could just take a crap off the block idk
It's not the same block
amceaglesx4
- Vehicle Make: amc
Its not really that much different besides the 4.2 has a fuel pump hole on the side.
Lol, ... Like John said. A lot more differences than just a fuel pump boss.amceaglesx4 wrote:Its not really that much different besides the 4.2 has a fuel pump hole on the side.
How about 1/8 smaller cylinder bore.
optmaxx
I could be wrong, but isn't there a way to grind a crank to get more displacement?
jeepxj3
- Vehicle Model: xj
Offset grind the rod journal of the crank.
But then you need to find a rod with a smaller big end and the correct length, etc.
amceaglesx4
- Vehicle Make: amc
Basically not really lol
