Help
Stroker Starting problems
BlackHawk18
I went to fire up the stroker for the first time and nothing... it doesnt crank, all i hear is click. I have swapped relays, and it is a new starter. I have power, the gauges seem to act normal. When I turn the key, all lights/ radio comes on but when I try and turn it over my radio turns off?
Help
Help
Re: Stroker Starting problems
This sounds like a power problem. Not enough Juice for the starter? Charge the battery?
nicpaige
- Vehicle Make: XJ
- Vehicle Model: Sport
Could be a bad ground cable. Take a jumper cable and hook one clamp to ground on battery and then the other end clamp to the block and then try it.
BlackHawk18
I have no breaks in the wire from my starter to the pcm. I am not getting getting power to the terminal wire on the starter. I have installed a new CPS and I have tested my NSS, it tested fine. I have swapped relays, fuel pump comes on, I have signal at my distributer and I am also still not getting spark....
Help..
Help..
moho
is it a standard safety switch on clutch peddle also i believe there is a 10 amp fuse that can cause no starting
BlackHawk18
It's an automatic.moho wrote:is it a standard safety switch on clutch peddle also i believe there is a 10 amp fuse that can cause no starting
I have looked at all the fuses, I bought new relays.
I have tested to see if there are any volts at the case on the starter and I got .7v (is that good or bad?)
I am getting 12.6v to the positive terminal on the starter
New CPS, pick up coil, cap, rotor, wires, and plugs
Help please! I am ready to blow it up!
rammit11
sorry to hear about your problems. I have a couple of suggestions ,don't know if you tried any of these yet. My first one would be to if possible pull the starter from the engine with it wired in and see if it engages. You say the starter is new, correct? if so I would take it back to where I bought it and have them test it to make sure that it is working, not the first time new parts have been bad out of the box.
amceaglesx4
- Vehicle Year: 1981
- Vehicle Make: amc
- Vehicle Model: eaglesx4
Honestly friend its not uncommon for them to have a flat spot in the starter. Roll it back two feet and tap a few times with a hammer then start it up. I've owned 3 starters with eventually a flat spot.
rammit11
hi, did you ever find an answer as to what was the cause of the problem? I just had a similar thing happen to mine ,had it in the garage for a couple of days went to start it and nothing but the click click of the starter , radio played fine etc. I took the battery back to where I bought it(only 2 years old) , they tested it and found a bad cell. put the new battery in and everything was normal.
