Fuel injection problems no more
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Vehicle Model: eaglesx4
Post by amceaglesx4 »
I have read so much despair on getting it right. Hers my thought if anyone cares. Google gronk carb adaptor. Its a spacer so you can put a two barrel carb on the 4.0 intake. Slap on a fuel pressure regulator and hook up a fuel muxture gauge and jet accordingly. Stock throttle body is 2.18 inches and the motorcraft 2 barrell is a 1.08 venturi. Times two is 2.16. Fuel issues are done.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Re: Fuel injection problems no more
Better yet modify the intake to accept a four barrell holley 390 or the oober rare carter 400 cfm which has a 1.06 venturi. Smaller the primary venturi the better throttle response and gas mileage. More air velocity better atomization equals better gas. Just my two cents.
Better yet: Leave the carb on the shelf where it belongs. Get the correct sized injectors and get a tune if you want. Its not that hard.
Stroker Displacement: 4.9
Post by jsawduste »
SilverXJ wrote:Better yet: Leave the carb on the shelf where it belongs. Get the correct sized injectors and get a tune if you want. Its not that hard.
Hmmm, let me guess. He is advocating 30 year old technology as a better way.
He is blocked to avoid reading his gibberish. Bet I am not far off based on your reply Chris Silver.
More fun this way.
:lol:
Strong Poster
Strong Poster
Post by Russ Pottenger »
The other obvious point. Carburetors work best on flat and level ground.
My Jeep spends a lot of time on ground that is neither flat or level.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
The 2100 is a great carb at steep angles.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Simple is better. Technology doesnt always mean better. Technology is always more expensive to fix and maintain.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Lol perfect example... What can cause misfiring , backfiring , surging and bucking as well as transmission shifting erratically ? Anyone ? Its called the coolant sensor on the thermostat neck !!!!! The coolant sensor is linked to all those problems. Technology just makes our lives happier and easier right ?
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Of coarse jsawduste knows that. He knows everything.
What can cause misfiring , backfiring , surging and bucking as well as transmission shifting erratically ? Anyone ? Its called a carburetor.
johnj92131
Post by johnj92131 »
Carbs are great on a 1960's car. Unless it is a Corvette. Then nothing beats Fuel Injection.
Last new car I had with a carb. was a 1985 Mustang GT. Ran great at sea level. Choked and sputtered like crazy when I got into the mountains, even with less than 1000 miles on it.
Carbs are for Luddites. https://www.google.com/search?q=luddite ... 8&oe=utf-8
Post by jsawduste »
:cheers:
johnj92131 wrote:Carbs are great on a 1960's car. Unless it is a Corvette. Then nothing beats Fuel Injection.
amceaglesx4
Vehicle Year: 1981
Vehicle Make: amc
Still have my 83 ttop. That holley was trashed years ago.
amceaglesx4 wrote:I have read so much despair on getting it right. Hers my thought if anyone cares. Google gronk carb adaptor. Its a spacer so you can put a two barrel carb on the 4.0 intake. Slap on a fuel pressure regulator and hook up a fuel muxture gauge and jet accordingly. Stock throttle body is 2.18 inches and the motorcraft 2 barrell is a 1.08 venturi. Times two is 2.16. Fuel issues are done.
Yeah I'm just itching to give up the EFI that's responsible for good driveability in all conditions, good fuel economy, and clean emissions to swap in dinosaur age technology. :lol:
I'm sure you'd be equally happy running Windows 3.1 on your PC as you are running a 2-barrel carb. ;)
There's also a flaw in your maths. A single 2.18" barrel has a C/S area of 3.73 sq. in. whereas two 1.08" barrels have a total C/S area of just 1.83 sq. in.
One plus one does equal two but one squared plus one squared doesn't equal two squared!
krom
Where's the "any" key?
Post by krom »
I'll try and be nice, but after reading on here, you have no chance of jetting a carb correctly...
Either take it to a pro for a diag and dyno tune, or trade your savings in for $1 bills, and build a nice fire.
