Snorkel on a stroker???
Killerfrog79
Post by Killerfrog79 »
New here, starting to buy parts to build my 4.6L.... just curious, do you have to run a cool air intake or can you run the stock air box with a snorkel? I have looked and searched for an answer to this, but I just cant seem to come up with anything. I have seen several places that the stroker only pulls like 380-390 cfm, and was curious if the stock air box and snorkel would do fine or not....
Re: Snorkel on a stroker???
Make your own CAI with the largest conical filter that'll fit in the available space. If you're going to be fording through water, install a snorkel mated to the stock airbox.
Snorkel is more restrictive than the stock air box.
SilverXJ wrote:Snorkel is more restrictive than the stock air box.
Indeed it is but it can also be life-saving for the engine in two situations:
1. When fording streams or large water holes.
2. Raising the intake opening prevents much of the low-flying dust generated by driving on dirt tracks from clogging the filter.
SkylinesSuck
Post by SkylinesSuck »
It is? Which one/kind?
I am well aware of the function of a snorkel.
SilverXJ wrote:I am well aware of the function of a snorkel.
I know you are. ;-) My comment was also aimed at others reading this thread.
