Newbies poorest man's stroker
TJW319
Where's the "any" key?
Vehicle Model: TJ
Re: Newbies poorest man's stroker
Post by TJW319 »
No problem, But it's TJW :lol:
I went with the short Rod because I had them and as my title suggests I'm on a very tight budget! I know that to most the cost difference is nominal, but right now every nickel counts, but I need to rebuild anyhow and have wanted to do a stroker for a long time and already had a crank and rods.
Yes, please hook me up with Dustin,
I've already talked to Chris so I think I'm covered there.
I'll talk to Russ and see what he suggests I do for a cam.
I guess the 809 is going to fleebay
Strong Poster
Strong Poster
Post by Russ Pottenger »
On a stock head with stock valve springs I
have a cam that Comp does for me that works well.
It's:
206 212 @ .050
.435 .448 lift
113 LSA
I've used this along with the 68-232-4 but with this cam
you have to be real careful setting up the installed spring height. You'll be about .060 from coil bind if using a stock, or stock replacement valve spring
TJW319
Vehicle Model: TJ
Post by TJW319 »
Hey Russ I emailed you before I saw your post. Please send me a cost on the custom cam thx
Stroker Displacement: 4.9
Post by jsawduste »
Russ Pottenger wrote:On a stock head with stock valve springs I
It's:
206 212 @ .050
.435 .448 lift
113 LSA
:worship: :worship: :worship: :cheers:
Out of curiosity TJW how about running the compression numbers with this new stick. Curious what your corrected to altitude DCR will be.
TJW319
Vehicle Model: TJ
Post by TJW319 »
I'll need to get the advertised duration from Russ and I'm curious too. 8:2 / 8:5 I'm guessing. :huh:
TJW319 wrote:I'll need to get the advertised duration from Russ
Probably the same as the CompCams 68-232-4 at 250/256 degrees.
TJW319 wrote:It seams like I read somewhere that there is a 65mm TB that came on mid 90's mustangs that works on the 4.0
You probably read it here:
http://www.angelfire.com/my/fan/MustangTB.html
I did it on my Jeep just 1150 miles after I did the stroker swap some 12 years ago (can't believe it's been that long!). AFAIK, nobody else was either brave or stupid enough ;) to copy my Mustang Cobra 65mm TB swap but it still works great after 83k miles of use.
TJW319
Vehicle Model: TJ
Post by TJW319 »
Well I'm definitely stupid enough :smack: but I'm going to try something else stupid first, I let you know later what it was depending on the out come.
My SCR @ alt is 8.07 at 1300 for daily driving an 7.63 at 3500 for an average trail
TJW319
Vehicle Model: TJ
Post by TJW319 »
Yep, that's where I saw it:)
Well it looks like what I did is gunna workout :banana:
Is there a way to attached a picture to a post?
TJW319
Vehicle Model: TJ
Post by TJW319 »
What you all think as far as using an adjustable map? I'm going to get a ChrisTuned ecu. The recipe a recipe couple post back with three changes is where I'm at.
Cam: 67-232-4 Russ modified
Time: straight up
64mm TB
You won't need a MAP adjuster if you have a Christuned remapped ECU.
Users browsing this forum: Ahrefs [Bot] and 3 guests
