Oil Reports indicate??
purple_jeep
Vehicle Model: GC
Post by purple_jeep »
Hi All,
So the last two oil reports have not been very good so I was hoping you guys could suggest things I can check?
Build thread is : viewtopic.php?f=8&t=4596
Oil report:
Oil pressure has also changed gradually:
Initally it was:
Idle 30psi
Running 45psi
Now it still idle's at 30psi running is closer to 40 but I noticed today that which holding at constant revs (1500ish) it will drift from 35ish to 40 and back.
Thoughts?
Cheers
Chris
Re: Oil Reports indicate??
Oil pressure is great. Can't read the numbers, but looks like more than normal aluminum and iron. Pistons are aluminum. Most other parts are iron.
purple_jeep
Vehicle Model: GC
If you click on the picture it gets bigger :p
Cheers
Chris
SkylinesSuck
Post by SkylinesSuck »
+1 on the oil pressure. What oil are you running?
I've never seen any positive results using Amsoil.
purple_jeep
Vehicle Model: GC
IH 392 wrote:I've never seen any positive results using Amsoil.
You think the oil choice could be causing the abnormal wear?
Cheers
Chris
Strong Poster
Strong Poster
Post by Russ Pottenger »
Cheers
Chris
No
purple_jeep
Vehicle Model: GC
Didn't think so,
Any suggestions on what to check/look at?
Cheers
Chris
I don't believe the Amsoil caused any undo wear?, but every engine and axle I've taken apart that used that crap was worn just as bad or even worse than if it had used regular old dinosaur oil. :huh:
I've been using Mobile1 in my engines and REDLINE in everything else that uses oil, plus I prefer oil that I don't have to mail order!, Amsoil is just about impossible to find out here!
purple_jeep
Vehicle Model: GC
Still no good, latest oil report shows no improvement, I will compression test and cylinder leak test this weekend.
Also will pull the valve cover, is it obvious if I have a collapsed lifter or a wiped cam lobe?
Cheers
Chris
