Timing videos on YouTube
bigal389
Vehicle Year: 2004
Vehicle Model: Wrangler X
Post by bigal389 »
Ok I've been looking at some videos on YouTube and came across this one:
http://www.youtube.com/watch?v=Ko75NEe2khY&sns=em
Can someone explain this? Everything I've read says this is 180* out
Al
Re: Timing videos on YouTube
He's obviously got the cam position sensor correctly placed there.
bigal389
Vehicle Year: 2004
Post by bigal389 »
I saw that but the way he set tdc was 180 out on the cam was it not?
bigal389 wrote:I saw that but the way he set tdc was 180 out on the cam was it not?
Nope. Both valves on the no.1 cylinder were closed so it was definitely at TDC at the end of the compression stroke.
nope, that is not how the sensor is installed. The window needs to be toward the rear. I don't know what the hell they are doing there with the paint and other BS. But that is not correct. It should look like this:
TR1Hemi
Post by TR1Hemi »
...and yet it runs fine.....I have never had or worked on a coil pack 4.0...so I can't comment on his "personal" procedure, but you can't argue with the results with him doing it on video, and it then running fine.
The only reason I can think of is that it is a waste spark system. Maybe that has something to do with it.
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
