Please review and critique My Stroker recipe
aaronmulder
Vehicle Model: YJ
Post by aaronmulder »
Hello, and thanks in advance for your assistance.
Last summer my son and I had a blast off-roading and we ended up in too deep of mud and hydro locked the jeep engine. Now were planning to build it "better" with a 4.6L stroker,
Stroker Build v2.xlsx
Re: Please review and critique My Stroker recipe
Looks good. However you won't be running 87 octane with option #1. I would also recommend a JP Performance/ Rollmaster for the timing set. Hylift-Johnson for the lifters.
aaronmulder
Vehicle Model: YJ
Thanks for the info, I found the JP timing set on ebay for $104, I'll send the other once back.
With the information entered into the calculator on the board I have the following:
SCR 10.57:1
DCR 9.07:1
Quench 0.043
Intake closing angle 55
Any issues with this running the 93 octane fuel?
THanks
Aaron
That will be fine on 93.. you might even get by on mid grade.
aaronmulder
Vehicle Model: YJ
Hello again all,
Now that all the machine work is complete I have a final decision on the head gasket thickness that I need some help on.
0.043" gasket will give me a SCR of 9.72:1 and quench height of 0.034"
0.051" gasket will give me a SCR of 9.57:1 and quench height of 0.042"
Which gasket would you choose and why? My goal is to have a engine that runs on pump gas.
Aaron
Go with the thinner gasket. The decreased quench distance should offset any problem with pre ignition.
Strong Poster
Strong Poster
Post by Russ Pottenger »
SilverXJ wrote:Go with the thinner gasket. The decreased quench distance should offset any problem with pre ignition.
X2,
That's why I like setting up my combinations off a 9.450
Block height with a 1.385 CD piston.
Targeting a piston to be .008 out allows for variances that could be made up with the two common choices of head gaskets.
Your piston rings are on the way.
Russ
