My 4.0 disintegrated a piston and there was no other choice but to go big or go home.
Thanks for all the research and info used
ShaPoops
x2jasonb wrote:Looks real nice! Tell us a little about the build.
Compression is on the mild side as is the cam. Don`t expect this to be anything but a torque engine.99jeepxj wrote:I had Casey send me a detailed email with what parts they use. My only killer is that it's on making 231hp and 321 for torque. I checked with golen and they are 270hp and 324 for torque.
Those two items are not a performance "upgrade", but rather what the engine needs to survive. If you are running lean on WOT with too small of an injector the engine will not be happy. Tulliped valves, melted pistons, etc. The fuel grade selection is in the same league. If too low of an octane for the compression ratio the engine will detonate.Shapoopie99 wrote: This build is totally compatable with stock Injectors and fuel systems as well as pump gas.
Users browsing this forum: Google [Bot] and 0 guests
