4.6 Stroker Input/ Opinions
Jrama403
Vehicle Year: 2004
Post by Jrama403 »
Completely new to anything engine internal, have been doing some reading and have some questions, looking for input on the build overall etc.
I want it to run 87 Octane
2004 Wrangler 4.0
Here is the Build I have so far
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
Icon 4032 +0.030" bore pistons, dish volume 21cc
CAM- 263/267 degree camshaft LSA 114
Stock 57-58 CC Cylinder head.
Stock size 0.051" head gasket
Stock deck clearance .0215
Calculated Static Compression Ratio = 9.24:1
Calculated Dynamic Compression Ratio = 7.39:1
Quench .0725
1. I need camshaft advice, really not sure were to head with it. Got my numbers from the Clegg Stage 1 kit http://www.cleggengine.com/stroker-kits ... t-kit.html
2. Any suggestions to improve the build? and still run 87 I.E. deck the block, use a piston with smaller cc, go .060 instead .030 etc.
3. I assume computer with the 04 will self learn?
Was going to go with RPM machine stage 3 Kit to achieve the above https://rpmmachine.com/amc-stroker-kit-4l.shtml
Strong Poster
Strong Poster
Re: 4.6 Stroker Input/ Opinions
Post by Russ Pottenger »
My input is that if your over .070 piston to head you don't have an effective quench
Decking the block, reducing the dish in the piston, and moving up to a 3.935 bore will bring the static compression up too high.
Tightening up the quench closer to .040 with a 24 to 26cc piston is the direction you want to go.
You're welcome to shoot me a call or email and I'll be happy to tell you how wonderful my stroker kits are
:mrgreen:
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
Cell (626) 673-2203
Jrama403 wrote:Completely new to anything engine internal, have been doing some reading and have some questions, looking for input on the build overall etc.
2004 Wrangler 4.0
I suggest you use custom pistons & custom cam from Russ and do this:
4.6L low-buck stroker
Custom forged +0.030" bore pistons, compression height 1.385", dish volume 25cc
9.5:1 CR (assuming 57cc chambers)
Custom camshaft
Russ Pottenger ported cylinder head (LS1 valves)
Victor Reinz 0.043" head gasket
0.038" quench height
Post by dwg86 »
Tighten up the quench. The stroker I built had close to the same compression numbers. I could run 87 octane with no problem. With that being said I thought I would have liked higher compression. It ran good, and better power than the stock 4.0, but I always thought it lacked a little something. Tighten up the quench and you'll be able to run a higher compression, or so I'm told.
Jrama403
Vehicle Year: 2004
Post by Jrama403 »
Really appreciate the advice! I have modified my build and I am Talking with Russ about assembling a kit.
Couple other questions
Which fuel injectors work with the 2004 4.0 ? I know 2003 + Motors ditch the distributor.
had these in mind https://www.summitracing.com/int/parts/ ... /make/ford
Also is it necessary to balance the rotating assembly on these motors?
johnj92131
Post by johnj92131 »
Here is a very good article about compression and quench, if you take the time to read it. Explains the how and the why.
http://www.hotrod.com/articles/0311em-power-squeeze/
Jrama403
Vehicle Year: 2004
Post by Jrama403 »
Ended up with the following build.
Jeep 4.0L 6.125" rods - Re-used from previous motor
Keith Black Hyper +0.030" pistons, dish volume 24cc
Moly piston Rings
CAM- 263/267 degree camshaft LSA 114 (I have the 505 Stage 1 cam)
Stock 57-58 CC Cylinder head. shaved down .006
Decked block to near zero .003
Static Compression Ratio 9.3:1
Dynamic at Elevation 7.2: 1
Quench: .048
Yes it runs Regular gas no issues, no engine lights or quirks and it pulls MUCH better than stock so far I am very happy with how everything has turned out! Ordered everything from 505 and Rock Auto, employed a couple of local machine shops for block/head and built the engine ourselves. Have about 500 miles on the Motor so far will let you all know if it blows up!
Glad you're a happy camper and are enjoying the new-found power. Just make sure the engine doesn't blow up! :D
