Thickest head gasket
Mopud
Stroker Displacement: 4.66L
Vehicle Model: TJ
Post by Mopud »
Hey all,
What's the thickest head gasket available for these 4.0l? I've now had .026" taken off the deck and 0.015" off the head. I was previously running the FelPro 9076PTI which had a thickness of .051" so would like to step up to bring the CR down as much as possibe. Are there any fatter ones out there? I have read about .060" gaskets but I've so far been unable to source.
Regards,
Anthony
2001 TJ 4.66L
Strong Poster
Strong Poster
Re: Thickest head gasket
Post by Russ Pottenger »
I have .060 Gasket's in stock Anthony.
Cometic makes them for me.
I'll be happy to put a Head gasket together for you along with your cam and pushrods.
Mopud
Vehicle Model: TJ
Post by Mopud »
I should have known to just ask you first :D
That would be great. Thanks, Russ.
Also are you happy with the Cloyes double roller? I've already ordered one but if there's a benefit to one of the others that you sell please let me know.
Regards
Anthony
2001 TJ 4.66L
Strong Poster
Strong Poster
Mopud wrote:I should have known to just ask you first :D
Regards
Anthony
The Rollmaster is a better timing set.
Mopud
Vehicle Model: TJ
Post by Mopud »
Add it to the list... :cry: :lol:
2001 TJ 4.66L
gonridnu
Vehicle Year: 1989
Vehicle Model: XJ 2 door
Post by gonridnu »
I use Cloyes Hex Adjust sets on anything that is not getting a belt drive. The hex adjust is quick and easy and we've put thousands of passes and thousands of laps on them without a single failure. The hex adjust feature makes degreeing the cam about as fast and easy as it can be. Of course I put one on the stroker as well.
Strong Poster
Strong Poster
The Rollmaster has billet gears with 2°incremental keyways on the crank gear with solid rollers.
Either way the Rollmaster and Cloyes timing sets are serious upgrades over OE
gonridnu
Vehicle Year: 1989
Post by gonridnu »
Hex Adjusts also use billet gears and solid rollers.
Russ Pottenger wrote:I have .060 Gasket's in stock Anthony.
I guess those must be custom made 'cause the only off-the-shelf Cometic head gaskets I could find are 0.040" and 0.050" compressed thickness respectively. I've updated a full list of available head gaskets on my site at http://www.jeep4.0performance.4mg.com/tech_specs.html
Feel free to add any comments or corrections.
