Old stroker refresh
YJLopes
- Vehicle Year: 1991
- Vehicle Model: YJ
Re: Old stroker refresh
I spent a while chatting with Russ on Friday and I am making progress on my game plan. I am going to buy a set of rods and pistons from Russ and use the head gasket to fine tune the quench. I should be able to dial it in down to the gnats ass! I'm still undecided on CR. I'm convinced that I don't want to be any higher than 9.5, but I'm still not sure why to push it that far. Any reason not to be down around 9-9.25?
To maximize hp/tq and get the best fuel economy, you'll want the highest CR possible that'll allow you to run the engine on your chosen grade of fuel without detonation.YJLopes wrote:I'm convinced that I don't want to be any higher than 9.5, but I'm still not sure why to push it that far. Any reason not to be down around 9-9.25?
Stroker Build Stroker Recipes
X2,Cheromaniac wrote:To maximize hp/tq and get the best fuel economy, you'll want the highest CR possible that'll allow you to run the engine on your chosen grade of fuel without detonation.YJLopes wrote:I'm convinced that I don't want to be any higher than 9.5, but I'm still not sure why to push it that far. Any reason not to be down around 9-9.25?
Couldn't of said it any better.
Some of my competitors out there are pushing combinations that utilize 27cc full circular dishes with 8.8:1ish static compression ratios normally aspirated.
That's a horrible recipe.
Don't forget the cam when deciding on a compression ratio.
IE dynamic vs. static
Indeed. Full circular dish = no quench area, and no doubt you're referring to the KB421 pistons.Russ Pottenger wrote:Some of my competitors out there are pushing combinations that utilize 27cc full circular dishes with 8.8:1ish static compression ratios normally aspirated. That's a horrible recipe.
