Jeep is a 95 XJ, 5 speed, 4wd, stockish. No crazy anything yet. Formerly my daily until blowing it up a couple months ago, was actually driving to buy a honda. Think the Jeep committed suicide.
 Once completed it will see ~95% street use, I'll take it to work (not my daily), drive it around town, it will be revved to redline, taken to the track, etc. Think mild street motor over low end monster. I would love to wheel it more but the nearest trails are 2.5 hours, the nearest 1/4 mile track is 1 hour. A mix of both should be fun.
I would like for the stroker build to not be the end of fun projects for this engine. If time and budget allows, I'd like to do a megasquirt setup as the next big thing, and a turbo setup after that. Planning to leave some room for boost in this engine (see where the E85 comes in?
 )By the way, budget is somewhat tight- but the jeep can sit and wait as I save and scavenge parts. I have another (far more comfortable) daily.
My 4.0 block, rods, and head will be kept. Planning on taking the bore out .060 because I can't really think of a good reason not to. It's getting bored anyway and won't cost more to take it .060 than .030. Therefore, free power? 4.0 blocks currently are cheap enough to be somewhat disposable in my mind. Block will be decked to zero. Going to have the rods shotpeened and port the head myself. I've done 2 strokes before and have seen how easily things can go downhill, so not planning on anything beyond a cleanup and polish on the exhaust ports.
Picking up a mostly complete 258 this weekend for $50. Score! I'll pull the crank and should end up ahead after selling everything else. (Anything worth keeping?) Also picked up a 99+ intake at the JY for like $20.
Piston choice is what has somewhat confirmed the idea of running E85. Initially, the goal was to be able to run 87 during normal driving and bump the octane once boost was added. After looking at the available pistons (and pricing out custom work) that kinda went out the window. KB944's might have worked, but spending $500 on a set of pistons isn't really palatable. I'm not good enough with a mill or CNC software to dish pistons myself (consistently...) and not interested in paying someone to do it for me. I'm planning on going with the silvolite hyperetectics for a more manageable $170 or so. This gives about 10.5:1 static and 9:1 dynamic compression with zero deck, 13.7cc dish, .043 HG, cam listed below. Totally manageable on E85 with room for boost, less room for error with straight gas.
Keep in mind when I say boost I mean a low boost setup on a smallish turbo, I have no interest in blowing up my nice and expensive engine.
E85 is very affordable and available locally, so I have no real issues with running it. The difference in price per gallon should offset the increased consumption. The added torque from compression should help with consumption if I baby it. In the end I'm not going to be that concerned with gas mileage, that's what the honda is for
 My question here would be if anyone has ran or is running these pistons, with what results? Also, I'm fairly sure they will be strong enough for what I have planned, assuming detonation/ running lean/ general garbage tune is what blows holes in pistons- let's assume I have everything under control. Obviously forged would be the best choice but hyperetectics are supposed to stronger than cast.
Prospective cam choice is the comp 68-232-4. Looks to be well suited for the mildly street oriented goals I have without too bad of an idle or off idle torque. Again, experiences running this?
Wow, this turned out longer than expected. Have quite a bit more in my head still. I'll cough it up next time.
Logan
