Hello,
Currently starting my "low budget" stroker build, and began with buying a used 4.0 motor as well as the 4.2 crank for $300 total. I also just recently received the Silv-O-Lite Hypereutectic Pistons 3241HC-030 in which I'm planning on using for my build so I'm going with .030 over instead of .060. I was wondering what connecting rods I should use with this, should i use the 4.0 rods from the donor motor, or buy 4.2 rods instead? I still have a alot of research to do so any tips or help anyone can offer me would be much appreciated, thanks!
Stroker build using Silv-O-Lite Hypereutectic Pistons 3241HC-030
Sharnick
Re: Stroker build using Silv-O-Lite Hypereutectic Pistons 3241HC-030
You'd have to use the 4.2L rods with those pistons. You'll also need to have the block deck milled to zero deck clearance to minimize the quench height and reduce the risk of engine pinging.
Sharnick
Cheromaniac wrote:You'd have to use the 4.2L rods with those pistons. You'll also need to have the block deck milled to zero deck clearance to minimize the quench height and reduce the risk of engine pinging.
Thank you! Any other suggestions for what I should have done at the machine shop or misc parts im gonna need to buy?
All the usual parts that you'd need for a stock rebuild plus a performance cam, lifters, valve springs, pushrods, and oversized injectors.
Just remember as you start decking the block and how it affects the static compression ratio.
It's certainly desirable to have a tight quench but you're not going to obtain it with that small dish.
Jeepitout95
- Vehicle Year: 1995
Noob here ((the more you learn the more questions you have). Tell me if I need to search the forum or not (don't wanna be a pain), but why are those pistons not ok to use with the 4.0 rods? Are they a larger piston?
They're too tall for the 4.0L rods and will be 0.2" above the deck at TDC.
Sharnick
Thank you to you and Russ, I decided to return those pistons and will be buying a set from Russ instead!Cheromaniac wrote:They're too tall for the 4.0L rods and will be 0.2" above the deck at TDC.
