Renix Stroker help
88mjolympic
- Vehicle Model: Comanche
Renix Stroker help
Hello fellow Jeepers. I just joined the forum. I’ve been reading a few posts before joining. Have a few questions about building a long stroke 4.6. I have an 88 MJ with a good running Renix. I’ve acquired a 93 4.0 block and 7120 head. I bought a 1990 4.2 for the crank and my local shop just called and they turned it 10/10. My question is who has run a stroker with all Renix controls? What tips can you provide as far as injectors? I hear most saying Ford 24lb and a few saying that was too much for the Renix. I’ve seen people use the 91-95 fuel rail on the Renix with a 99 up intake. I previously upgraded my 4.0 to the Volvo 4 Hole injectors. Sorry so long
Re: Renix Stroker help
I ran Ford Racing 24lb injectors on my stroker but then mine had a ported HO head, '01 intake manifold, and all the usual external performance bolt-ons.
You could run the HO head, '00+ intake manifold, HO TB with adapter for Renix TPS, '91-'99 header, and '91-95 injector rail with Bosch 0280155715 injectors (22.4lb/hr @ 39psi). You'll need to delete the EGR if you go with HO hardware, but you can still run your Renix controls.
Stroker Build Stroker Recipes
88mjolympic
Thanks, Yes I'm aware of the needed TPS adapter. I'm assuming I would use the HO IAC in the HO throttle body? It would most likely require an exchange 62mm bore tb. I havn't checked yet but is the connector for the IAC plug and play? Do you recommend eliminating the Renix vacuum harness assembly and CCV system and using the HO PCV system? I work at a (Ford) dealership as a long time parts manager. Luckily, one of our technicians used to work for an independent garage and he said I can use his Snap On MT2500 diagnostic scanner. He has the Jeep-Chrysler module for it.
