Is my block trash?
Sharnick
Is my block trash?
Just finished tearing down the 4.0 block I bought to use for building a stoker and found this hole behind the timing chain cover. Figure this means my block is garbage now and I'm out the $400 i bought this for, but decided to post on here just to make sure anyways. Thanks.
- IH 392
Re: Is my block trash?
They're all like that, if it really bothers you grind out the flashing when you clean the block.
Sharnick
Really? Looks jagged so I was concerned somehow it blew a hole.IH 392 wrote:They're all like that, if it really bothers you grind out the flashing when you clean the block.
There's supposed to be a hole there to allow oil drainback from the head to lubricate the timing set.
Yours just looks rough around the edges.
Sharnick
Thanks!Cheromaniac wrote:There's supposed to be a hole there to allow oil drainback from the head to lubricate the timing set.
