QUESTIONS ON A 98 TJ 4.6 STROKER
Re: QUESTIONS ON A 98 TJ 4.6 STROKER
Post by John »
What SilverXJ said and disregard the headers heating up for now, pretty normal.
http://www.youtube.com/watch?v=1CeuA6MuedA
A bit off topic, but notice the shot at the end... glowing down pipe... awesome video though.. had to post it.
heartlandoffroad
Stroker Displacement: 4.7 turbo
Post by heartlandoffroad »
Chris,
I looked at the link that you posted for me and that is the way that I do it and yes I did have to cut the ears off the distributor to get it to line up correctly.
Garrett
Then we can eliminate the distributor as the problem.
How did you put an adjustable fuel pressure regulator on it?
heartlandoffroad
I put bulk head fittings in the tank put a Airtex rail pump on and a Aero Motive adj FPR in line and returned back to the tank. All 3/8 braided line. Capped off the stock pump and regulator and left in place.
Ahhh... interesting way around the in tank regulator and filter. What is the fuel pressure now?
heartlandoffroad
49lbs
heartlandoffroad
We finally got this thing figured out. The builder didn't put the rite valve springs on it ( still had the stock springs on it). Runs great now.
Post by John »
Glad you ran this aground. Built in mechanical rev limiter. Did they reuse the old springs, what did you install?
heartlandoffroad
Yes they did reuse the stock ones.
I used Comp Cams 926-12 Springs, 744-123 Retainers, 603-1260 Locks
seanyb505
Stroker Displacement: 280ci
Post by seanyb505 »
Good info to know, my machine shop advised against installing 5.9 springs and so we just reused my stock ones, for break-in at least.
97 XJ 4.6
90 MJ 4.0 - sold
jeepinwi
Learning to use the board
Post by jeepinwi »
Very interesting thread. I'm running a Crane 753905 cam with stock valve springs, and it pulls strong up to 4800 rpm's. After that, it seems to make more engine noise than thrust.
Your stock exhaust could be one reason why your engine feels sluggish above 4800rpm. Another could be the stock valve springs causing valve float.
Sighman
Where's the "any" key?
Post by Sighman »
heartlandoffroad wrote:We finally got this thing figured out. The builder didn't put the rite valve springs on it ( still had the stock springs on it). Runs great now.
Good job on hunting this down, I need to have a friend like you!!!!!!
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
