AEM F/IC Basic Setup
Re: AEM F/IC Basic Setup
I found that 4.7Kohm-10Kohm resistors allowed you to offset the O2 voltages without the pcm fighting you.
darkcorp
- Vehicle Make: JEEP
- Vehicle Model: GCh 4.0
Hi guys!
I've bought AEM FIC 6 1910 for my 4.6 stroker. I know for Chrysler engine I should use 1913 version to eliminate MIL for injectors but I've found only 1910 version in my country.
One of my mate uses AEM FIC 6 1910 without throwing MIL. He connected additional 6 old Jeep injectors from junkyard and it works well.
Is it right or I can add some inductor coils instead? If yes, then could you tell parameters of inductor?
darkcorp
I don't understand why one picture wasn't attached.
darkcorp
Hi guys!
Can you show basic settings for AEM FIC 6 for Jeep?
I've installed AEM, but engine roughly starts and stop in second. MAP shows 9kpa instead of 100 kpa on stopped engine.
Cummins90
What is your map clamp voltage set to? Map is an intercept connection. Map "in" goes from the sensor to the FIC, map "out" goes from the FIC to the PCM.
darkcorp
Checked wiring, it's ok.
Gave 1.5V to MAF input to FIC (1.5V battery), AEM shows 1.5V in program and gives 1.5V to ecu.
Cummins90
Start a new thread detailing your set up. I can only assume what you have for a set up but try to Zero out your MAP map. In the settings menu put your map clamp max to 4.9v. Does it run? Does it run correctly with stock injectors and bypass harness?
darkcorp
Can you show me your setup settings please?
Here are mine
Here are mine
darkcorp
Finally started!
Cummins90
What was it?
darkcorp
Couldn't say exactly. Maybe harness or maybe base settings.
How do you start to tune AEM FIC on stroker?
Cummins90
Start a new thread with the details of your build.
