Cam Pictures
Cam Pictures
Here are some cam shaft pics I took today(Sorry some didnt turn out real clear). I don't think it would be possible to mod the old style cam to work with the cam retaing plate.[
Re: Cam Pictures
more pics
Plechtan
- Vehicle Model: Comanche
Re: Cam Pictures
Looks like the top picture is upside down. I think the retainer is a better idea, but I don't think you can use it with an aftermarket Cam.
Peter Lechtanski
Re: Cam Pictures
more pics
Re: Cam Pictures
And still more pics.(can only attach 3 at a time)
Re: Cam Pictures
old style cam with retaining plate sitting on front (for reference)
Re: Cam Pictures
Yes it is upside down, on an engine stand. Good eye.Plechtan wrote:Looks like the top picture is upside down. I think the retainer is a better idea, but I don't think you can use it with an aftermarket Cam.
Re: Cam Pictures
Dont forget that you can use an image hosting company to host the pictures. This is the preferred method, and would allow you to post more than 3 images per post.
viewtopic.php?f=19&t=112
Re: Cam Pictures
What gear set is that on the earlier cam?
Re: Cam Pictures
JP performance. I got it off ebay. Rollmaster makes a simular set...also on ebay. The cam and crank gear are billet steel. The crank gear has 9 keyways for adjustment
(-8,-6,-4,-2,0,+2,+4,+6,+8)
Re: Cam Pictures
Thats what I thought. Most likely going to get the same one.dwg86 wrote:JP performance. I got it off ebay. Rollmaster makes a simular set...also on ebay. The cam and crank gear are billet steel. The crank gear has 9 keyways for adjustment
TurboTom
Re: Cam Pictures
I wonder if I could shorten the bearing surface on the old style cam to fit an adapter that made it work with the thrust plate and newer style gear?
1979 AMC Spirit
Building a Turbo 2.5
I am not very smart!
1979 AMC Spirit
Re: Cam Pictures
If you could figure something out, that would be great. I would like to see something done to use the retaining plate. I looked at it a while, but then figured it wasn't worth my time or money. The spring and pin will work for what I am going to use my engine for.TurboTom wrote:I wonder if I could shorten the bearing surface on the old style cam to fit an adapter that made it work with the thrust plate and newer style gear?
I think the biggest problem is going to be the oiling hole and the pin one the front bearing surface. The newer style cam is longer from the front of the block forward. Also, as far as I know, no one makes a double roller timing chain for the newer cam.
TurboTom
Re: Cam Pictures
Could you measure the base circle and the cam casting diameter between the 2 cams?
The 4.0 looks beefier
1979 AMC Spirit
1979 AMC Spirit
Re: Cam Pictures
I'll measure when I get home tonight.
