Is there any reason not to have zero deck height?
seanyb505
Stroker Displacement: 280ci
Post by seanyb505 »
For some reason when I started researching I got the idea it wasnt that great of an idea to deck the block that much. Now Im seeing a couple people actually shoot for zero deck height. Is there anything wrong with taking .0495 off the block?
97 XJ 4.6
90 MJ 4.0 - sold
Stroker Displacement: 4.9
Re: Is there any reason not to have zero deck height?
Post by jsawduste »
A loaded question with many variables. Taken at face value the only thing that would change is your valve train geometry. Length of the cylinder head bolts is another question. Though I suspect there is enough latitude here.
93 4.0 block
12 weight 4.2 crank
.080 Diamond pistons
Eagle rods
balanced
274/480 Cam
Mopar rollers with Engel springs
.043 Quench @ 9.48 Compression
Ported head
01 intake with 64 mm TB
Edlebrock header
Misc other stuff
Don`t need a Hemi.
Flash
Post by Flash »
No problem at all just as long as you quench is at least .045 your safe.( .002" below deck and and a .043 head gasket = .045"
The reason some don't deck the block, or don't thing is a good idea, is those that will spend the extra cash for the custom piston.
If the piston set up further in the bore it will stop sooner at the bottom(More piston skirt supported at BDC (Bottom Dead Center)
for those of us, that will be using stock 4.0L piston..........Decking the block will make "0" affect on this.
Flash.
Flash
Post by Flash »
jsawduste wrote:A loaded question with many variables. Taken at face value the only thing that would change is your valve train geometry. Length of the cylinder head bolts is another question. Though I suspect there is enough latitude here.
Good point, I hadn't even thought about the head bolt :smack: and yes if you deck more then a several thousands of the deck.......You will be buying shorter push rods or shimming the rocker arms for proper preload at the lifter.
Flash.
Post by jsawduste »
Flash, please don`t travel down the road of shimming stock rocker arms.
93 4.0 block
12 weight 4.2 crank
Eagle rods
balanced
274/480 Cam
Ported head
Edlebrock header
Misc other stuff
Don`t need a Hemi.
seanyb505
Post by seanyb505 »
I knew about the valvetrain....my shim kit actually arrived yesterday. Even if I go to zero deck Im still sitting pretty at 9.23 CR. Would bolts have to be altered? Ill be using the 258 rods, so zero deck can be acheived by decking the block .0495", I just didnt know if it was safe or not.
97 XJ 4.6
90 MJ 4.0 - sold
Flash
Post by Flash »
seanyb505 wrote:I knew about the valvetrain....my shim kit actually arrived yesterday. Even if I go to zero deck Im still sitting pretty at 9.23 CR. Would bolts have to be altered? Ill be using the 258 rods, so zero deck can be acheived by decking the block .0495", I just didnt know if it was safe or not.
I Don't know?????? ask you machines and let us know what he recommends, or how much you can get a way with before shorter bolts are needed??????
Hmmm i have never heard of any one talking about shortening or replacing with shorter bolts????????
A some point this could be important.
Here's another question.........How thick is the deck?????
Flash.
seanyb505
Post by seanyb505 »
Im going off of what is listed on the stroker calculator for deck height, which I dont have on this computer so I dont know off the top of my head.
97 XJ 4.6
90 MJ 4.0 - sold
Shark
Consistent
Consistent
Post by Shark »
shorter head bolts shouldnt be a big deal. just take a chop saw and cut off the machined deck height. grind down the rough edges. the stock bolts are plenty long. dont think there would be a problem with losing too much of their strength.
'95 XJ 4door 4.0 aw4 2" 31's
4point6
I think I'll order a "tab"
Post by 4point6 »
jsawduste wrote:Flash, please don`t travel down the road of shimming stock rocker arms.
What is wrong with using shims? I was planning on using these to compensate for decking the block 0.040 +/-:
http://store.summitracing.com/partdetai ... toview=sku
Says they work with the 242. I'd like to not go with custom pushrods, but if shims are bad news, then I'll have to reconsider.
-Andy
'97 XJ 4.6L Stroker
'00 Explorer
'67 Mustang Fastback (project)
seanyb505
Post by seanyb505 »
I was poking around the hesco site the other day and the have different length pushrods for around 40 a set. What are the lengths of the stock rods?
97 XJ 4.6
90 MJ 4.0 - sold
4point6
Post by 4point6 »
seanyb505 wrote:I was poking around the hesco site the other day and the have different length pushrods for around 40 a set. What are the lengths of the stock rods?
My FSM says 9.640" - 9.660", 5/16" diameter
-Andy
'97 XJ 4.6L Stroker
'00 Explorer
seanyb505
Post by seanyb505 »
The ones I would see being most relevant are 9.5" and 9.547", and you would need to take .093" off the head and block combined to make the most use out of the 9.547" rods. Thats a lot to take off, it looks like if I were to go to zero deck and take .015 from the head the shortest I could go with would be 9.575". I dont need to go to zero deck, so by taking .045 from the block and .015 from the head I would only need a .060 shim for each rocker, and since I have that exact size I think Im ok. But now with the production of the KB pistons which can use the 4.0 rod, Ill have to see which direction regarding zero deck height I take based on price.
97 XJ 4.6
90 MJ 4.0 - sold
SIXPAK
Consistent
Consistent
Post by SIXPAK »
I have in the past decked over .090 on a HIGH [14+] comp motor without issue. Adjust push rod lenght as needed.
seanyb505
Post by seanyb505 »
Im sure its possible; I was referring to my particular build.
97 XJ 4.6
90 MJ 4.0 - sold
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
