jeep exhaust flange turbo manifold
				Wax
- Stroker Displacement: 4.0
I have drawn and checked a exhaust flange. The test is cut out of wood and of course will not work.
The hole down one end needs slotting and i will do that today and update to allow for expansion
I would like to share the dxf up here so we can all make turbo manifolds but im not sure if I can. I do not want to email this to every one so that is not happening.
				Wax
Re: jeep exhaust flange turbo manifold
Ok its been updated
				TJryder
Much appreciated!
You can upload attachment and rename it to whatever - just let us know what to rename it back so we can open it.
I am not sure which file types are allowed - but for sure it works this way with open forum system. We have used it a couple of times on one local forum.
Most modern CAD systems can open PDF files and convert back to DWG /DXF line system...
So PDF is a great start.
For instance - I attached dwg renamed to pdf BR M
							°O|||||||O°
				Wax
Ok here it is
You will need to rename its extension to dxf
It was done on a 630 head and fit with a new and old manifold
Your welcome, lets see those manifolds
						- darkcorp
- Vehicle Make: JEEP
- Vehicle Model: GCh 4.0
I've found that Boostwerks Engineering are going to realize a turbo manifold for 4.0!
https://www.facebook.com/BoostwerksE/po ... 104673151/
						- darkcorp
						- darkcorp
				Cummins90
Are you looking for one?
						- darkcorp
Yeah in my dreams.
I guess it will make a turbo setup much easier.
				Cummins90
Sometimes dreams come true. Check your inbox.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
