Retro engineering
JeeperJack
Retro engineering
Think before you speak. My. 85 CJ still has the stock 2.71 gears. I want to go to 31 tires. Low end torque is vital. Has anyone ever considered a 4.6 poor mans short block with a slightly reworked 4.2 head? I have a 4v intake and a several sizes of eddie carbs. Smaller ports and valves would enhance low speed velocity. Larger chamber would lower compression just a bit. Just really looking for 1500/ 3000 max torque. Any thoughts?
Re: Retro engineering
I'm not sure why you'd want to build a stroker and have it drinking through a straw (the 4.2 head). A ported 4.0 head will allow the engine to produce more torque across the whole rpm range. Mine produced at least 90% of maximum torque from 1500rpm to 4500rpm (peaked at 3500rpm). The smaller kidney shaped chamber of the 4.0 head has better combustion efficiency resulting in better gas mileage and lower emissions. I suggest you also use an '00+ intake manifold and make an adapter plate to mount the carb.
JeeperJack
Thanks. I concerned about the compression with a poor man's build. 9+ and spark knock is something I'm not wanting to deal with. A better price on the lower comp pistons would be great. What cam did you use?
I reused my stock '92 cam.
I suggest you go with the modified poor man's using the 4.0L rods and Russ' custom pistons. With a CR in the low 9's and a tight quench, you'll still be able to run 87 octane gas.
The '00+ intake manifold will also help as the curved runner design allows a more homogeneous distribution of the air/fuel mixture to all cylinders.
You might end up spending a bit more but you'll be much happier with the end result.
This ^^^^^
dirtdudeaz
- Vehicle Year: 1983
- Vehicle Model: CJ7
You mentioned your gears, almost expecting a question about them. A motor will help get you power, but are there plans to change your gears too? What trans do you have (T-176?)? I think you'll still fight your tall gearing for any low RPM torque you gain in a stoker. Just curious, what type of driving do you do...
I agree. With 31" tires and a 4.6 stroker, I'd suggest either 3.73 or 4.10 axle gears. They'll make a massive difference compared to the 2.71. Keep in mind that you'll need to change the speedo drive gear in the transmission tail housing to correct for the axle gear change.
Users browsing this forum: Google [Bot] and 3 guests
