Stroker kit opinions
Sammyguy
- Vehicle Year: 2002
- Vehicle Model: Tj sport
Opinions on this kit https://www.cleggengine.com/stroker-kit ... -kits.html and this cam combo https://www.cleggengine.com/jeep-4-0l-s ... t-kit.html I recently purchased both and the block is currently being bored 30 thou over and honed. I also oreded the 24 lbs 6 hole injectors from them as well what kind of power should i expect?
Sammyguy
Re: Stroker kit opinions
Ordered the stage 2 stroker to be clear
The low 8.8:1 compression combined with the longer duration cam isn't ideal for low rev torque production. On the plus side, you'll have no problem running 87 octane fuel.
The Clegg kit is fine except for the ICON pistons that leave ~0.027" of deck clearance unless you mill the block deck.
Stroker Build Stroker Recipes
Sammyguy
As long as it makes more power im happy i dont do much low speed rock crawling anyways I do more sand and mud and am looking to turbo or supercharge in the future
Cummins90
Sammyguy
ok so the machine shop had to take 8 thou off the head to get it flat what difference is this gonna make on my compression ratio?
It''ll increase by 0.11:1 i.e. too little to make any difference.
