Jeep Cherokee XJ SRT6 Build
Cummins90
Hey I have this build in a couple forums and at some point it will get a stroker motor so why not here as well. It would have been cool to see team viper/pvo pick up the idea of a performance package for the late 90s early 2000 cherokee. Sadly they didn't but this is how I would have liked to see it done.
Cummins90
Re: Jeep Cherokee XJ SRT6 Build
Started with a very stock XJ.
Cummins90
Remove the intake and exhaust. Pull the block coolant plug.
Cummins90
Oil drain and oil feed.
Cummins90
Prep the turbo to manifold.
Cummins90
Hook up the block coolant feed to the lower port on the turbo. The upper coolant will loop over to the heater core inlet. Tip the manifold runner number 1 up and attach the downpipe. Pull it back into position and thread the oil drain into the pan.
Cummins90
Install your narrow and wideband sensors. Install the oil feed line on the turbo and run it up through the intake manifold as you install it.
Cummins90
Install your charge pipes and intercooler. I cut my bumper and put it there. I installed champion spark plugs from an 88 XJ. Run your vac lines and boost ref lines.
Cummins90
Here is the engine bay all together. Gauges are in. Boost, AFR and trans temp.
- SkylinesSuck
Really enjoying this thread. Moar!!
Cummins90
I have more install tech stuff on the way. What else you want to see?
TJryder
Everything!
°O|||||||O°
Tolemar
Tolemar
Nice! is that your new cast turbo exaust manifold? How are you supplying the extra fueling and retarding the timing curve if it needs it. Hows it run and how much boost? Are you tuning the jtec computer yet?
Cummins90
The manifold is mild steel welded together on a fixture, I have a bunch of them. I use an aem FIC but also have HP as well. Just havent had any free time lately due to the Cov.
