On Going Problems
azcurly
Vehicle Year: 2006
Vehicle Model: Unlimited
On Going Problems
Post by azcurly »
My project started in September of 2018 and continues. I have a 2006 Wrangler Unlimited which I had a mechanic drop an ATK 4.7 which ran for about 150 miles. I fought to get my money back which I used for Golen 4.6. First engine had sensor correlation issues and the bearings toasted in about 600 miles. 2nd engine resulted in about 600 miles and over fueling causing the bearing to go again.
The Jeep, now has the 4th engine and it has all new OEM sensors and correct fuel pressure but still over fuels. The shop and Golen seem to be avoiding me. Also during the shipping the fancy valve cover was cracked with both places saying it aint their fault.
The engine from Golen, comes with 24lb injectors which my gut is telling me is overkill.
Now two weeks before hunting elk, the jeep is not available to use. To date, the costs are around 12k.
My brother is going to pick up the jeep and see whats up. He has built a 69 Camero with a LS, has a C10 with an LS and is building a CJ7 with a LS3. I think he may be able to figure out the overfueling issue before it gets trashed again.
Questions for all of you;
What Aluminum Valve Cover will work
What would cause the overfueling
Would putting stock 4 hole injectors be better
Any help is appreciated
azcurly
Vehicle Year: 2006
Re: On Going Problems
Post by azcurly »
Golen is coming through on the Valve Cover
275/350 I-6
Vehicle Year: 1985
Vehicle Make: AMC
Vehicle Model: CJ-7
Post by 275/350 I-6 »
What are you running for fuel pressure?
How do you know it’s over fueling?
I’m new to these engines, so I’m trying to learn from your dilemma.
If you take it to your brother, he’s gonna was to put an LS in it...lol
SkylinesSuck
Post by SkylinesSuck »
If you toasted bearings because your engine was running too rich, I don't see how that is your engine builder's fault.
Strong Poster
Strong Poster
Post by Russ Pottenger »
SkylinesSuck wrote: October 3rd, 2020, 5:02 am If you toasted bearings because your engine was running too rich, I don't see how that is your engine builder's fault.
X2,
Gasoline isn’t a good lubricant.
Cummins90
Post by Cummins90 »
What is your wideband reading? If you dont have one, get one. At this point its a drop in the bucket toward the total cost you've invested.
fhunziker
Vehicle Year: 2001
Vehicle Model: WJ (GC)
Post by fhunziker »
Just curious if this was ever resolved? I'm having persistent random misfires with my new Golen 4.6 in my 2001 WJ. My mechanic seems to think it's a controls issue and not fuel but I'd like to explore all avenues.
