2001 Jeep 4.0 -> 4.6l Stroker
bnelson
Vehicle Year: 2002
Vehicle Model: TJ
Re: 2001 Jeep 4.0 -> 4.6l Stroker
Post by bnelson »
I highly suggest you talk to Russ, very nice guy and easy to talk to about all these questions. He has the cam you need, piston and rod combo's that work correctly and will probably save you some $ in machining costs.
BClark
Where's the "any" key?
Vehicle Year: 2001
Post by BClark »
I have talked to Russ and he agrees that my plan sounds pretty solid. Anyone prefer Clevite or King main and rod bearings?
BClark
Vehicle Year: 2001
Post by BClark »
bnelson wrote: October 15th, 2020, 1:21 pm I highly suggest you talk to Russ, very nice guy and easy to talk to about all these questions. He has the cam you need, piston and rod combo's that work correctly and will probably save you some $ in machining costs.
Also, what headgasget will work for me? The Mopar one is too expensive to me
Kratos
Post by Kratos »
Fel-Pro has a good one for like 50 bucks. It’s .040 thick but it has a 4 inch bore. Part # is 26211PT .
BClark
Vehicle Year: 2001
Post by BClark »
blay127 wrote: October 15th, 2020, 12:44 pm Thought I'd throw this out there since you were considering a lot of the parts that I have in my motor.
I didnt build it so I dont know the specifics, was told (receipts for proof) that it is a Clegg's Stage 3 kit with the Stage 1 cam. Pretty sure its a non ported 0630 head, ebay stainless header, 2.5" collector and 2.5 pipe out to a flowmaster hushpower muffler.
But you can listen here and get an idea of the idle sound and then a quick rip up to about 4000 rpm.
https://flic.kr/p/2jgPtjv
Sounds sick👍 are you pleased with the engine? Good power over stock? Any issues with it?
Strong Poster
Strong Poster
Post by Russ Pottenger »
Kratos wrote: October 15th, 2020, 6:33 pm Fel-Pro has a good one for like 50 bucks. It’s .040 thick but it has a 4 inch bore. Part # is 26211PT .
Just a heads up. That Fel-Pro gasket is nothing more than a repackaged marked up Victor Reinz/Mahle MLS gasket.
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 2 guests
