Newbie planning on stroker possibly for her CJ7
Princess__Jamie
- Stroker Displacement: 258
- Vehicle Year: 1983
- Vehicle Model: CJ7
Looking to build a basic no frills stroker. I am looking at running 87 if need be but want the same reliability of my current 4.2. currently my 4.2 has 220k miles and needs head work and I'm entertaining the idea of a stroker swap. Carb or efi doesn't bother me as much as refreshing the last part (it's engine) for my DD/Trail CJ7 build. Pic of the subject.
Princess__Jamie
Re: Newbie planning on stroker possibly for her CJ7
Pic below
What's your budget?
Are you planning to buy a junkyard 4.0 to rebuild yourself, or do you want to buy a ready built stroker ready to drop in?
A carb set up would certainly be a lot simpler since your CJ wasn't originally fuel injected, so I'd advise you to take that route. An aftermarket intake manifold e.g. Offenhauser with a Holley 500cfm carb, plus your own choice of header with 2.5" exhaust system, should do nicely.
Princess__Jamie
I'm going to build the engine outside the Jeep first. Was thinking tbi and adapting an extra manifold I already have to the 4.0 head. If I just put a 4.0 head on a mildly bored 4.2 I would probably stick with a carb. I was going to do a core exchange with mabbco and just give them the internals to put together since I'm local in TX. The said they would machine and assemble the block for 1k which is hard to argue. I guess right not I'm entertaining all the different ideas currently.
That 1k rebuild seems too good to be true. If you price the parts out they add up pretty quickly. What exactly will they be replacing and what machine work will they perform ?
The 4.0 with your 4.2 crank might be an alternative to consider. The ROI would be greater due to the 4.0`s larger bore size. There is this guy Russ that lurks here on occasion. He is quite knowledgeable on putting together packages that work well together. Plus he can advise you with the proper information on just how the block and head need to be machined. There are a few critical areas of attention that separate a good stroker from a sub par one.
Take it 60 over, use his piston and rod combinations that match the head. Square the block up well and line hone the mains and the cam tunnel.
One word of advice, whereas a 87 octane engine is feasible it leaves a lot on the table. Making it an 91 or even a 93 will give you a better setup and your tuner person will love you more for it.
Good Luck,
Grumpy old man.
Good Luck,
Grumpy old man.
