Hi guys i am living in Africa and there are no performance engine shops here. So its a do it your self. I busy with a 4.6 stroker
Part list
Edelbrock Aluminium head
Roller rockers 1.6
Cosmetic head gasket, MLS, 4.000 in. Bore, .040
COMP Cams CL68-239-4
62mm throttle
Banks Torque headers
63mm into 76mm full exhausts
Ecu unlocked with Hp tuners with premium fuel map
The question is the full scat rotating assembly with comp ratio of
9.6 or 10.7 ?
Fuel used will be 95 octane (93Ron)
Calculated compression ratio with 10.7 kit
Static 10.81:1
Danamic 9.47:1
Calculated compression ratio with 9.6 kit
Static 9.67:1
Danamic 8.49:1
What stroker kit would you recommend?
Compression ratio
Madmic2980
- Vehicle Year: 2006
Re: Compression ratio
Given that you'll be using 95 RON octane (91 US octane) I'd recommend you go with the lower 9.6:1 compression ratio.
Stroker Build Stroker Recipes
Madmic2980
Does anyone know if there is any virtual engine dyno program thats any good to test out compression and cam combos ?
Here ya go:Madmic2980 wrote: ↑November 4th, 2021, 5:02 am Does anyone know if there is any virtual engine dyno program thats any good to test out compression and cam combos ?
https://www.motionsoftware.com/Dynomation6.htm
