Victor makes a thinner MLS (Multi Layer Steel) head gasket for the 4.0. See here http://www.jeepstrokers.com/forum/viewt ... ?f=5&t=472
It is Victor Part Number 54249S. I and another on the board here have mic'd it and it is .038 to .040. Obviously with a zero deck block, that would give you great quench numbers, but will also kick your compression up some....and of course don't forget to add the difference between stock and this gasket so you know how much you have to modify your valvetrain.
Bratcop
Decking vs. thinner head gasket
bratcop
- Stroker Displacement: 4.5L
Re: Decking vs. thinner head gasket
2001 GC Laredo
4.5 Stroker, 9.6 SCR, 8.1 DCR
Stock Valvetrain
24# Cobra Injectors
Bored Throttle Body
CAI
Ported and Polished 0331 Head
Zeitroniz WideBand O2 logger
Stock Valvetrain
24# Cobra Injectors
Bored Throttle Body
CAI
I don't think taking that much of the stem off is a good idea. According to the FSM the most you can take off is .010".. past that and you will run the risk of getting into non-hardened valve stem.Mgardiner1 wrote:the machinist can probably take .020 of the top of the valve stems without affecting retainer clearance.
- Mgardiner1
I stand correctedSilverXJ wrote:I don't think taking that much of the stem off is a good idea. According to the FSM the most you can take off is .010".. past that and you will run the risk of getting into non-hardened valve stem.
- Flash
Just adding a little extra to this..................with a 1.6 rocker arm, it would have required .032" cut off of the valve tip for .020"deck or head shave................Which would affect the geometry of the rocker arm, even more then the shim under the rocker arm pivot. Rocker arm would be on a down hill slope, before it started to open the valve.Mgardiner1 wrote:I stand correctedSilverXJ wrote:I don't think taking that much of the stem off is a good idea. According to the FSM the most you can take off is .010".. past that and you will run the risk of getting into non-hardened valve stem.
Flash
Users browsing this forum: Google [Bot] and 3 guests
