Hi, everyone!
I'm first time poster. Also Its my first Tj build.
Im looking for some opinions on my stroker build. I feel my dynoed HP at the wheel is way to low. I purchased most the parts from Clegg. I had the stroker built at a local machine shop.
I hope this doesn't come across as being paranoid, however the parts I built I feel should have gave me much more HP.
Im wondering if they actually madie it into the motor.
Please advise.
List of parts:
Stage 3 Hypereutecitc piston .060 over.
Hasting moly ring.
Scat Crankshaft.
Scat 4340 connecting rods.
Clevit rod and main bearings.
Balanced Rotating assembly.
Stage 1 cam kit with howards lifters.
Clegg/ harland, roller rocker arms
24lb injectors.
62mm throttle body.
FlowKooler water pump.
Melling oil pump.
Work done:
I wont list every thing.
Resurface block deck.
Resurface cylender head.
Ballanced parts.
Port heads.
Bore to .060 over.
Valve grind.
Dyno results:
Compression test: 160 per cylinder.
Last dyno pull,
hp - STTPrw Max 171.1.
STPTrq Max 220.5.
Lamb_1 Max 0.875.
I'll be honest I have no idea if these numbers are good or bad.
Im a home mechanic, learning as I go.
Im wondering if my cam is not aggressive enough.
Thank in advance!
Stroker numbers nowhere near what I thout it should be.
- Vehicle Make: Wrangler
- Vehicle Model: Rubicon
Re: Stroker numbers nowhere near what I thout it should be.
170 wheel HP. What tire size? What transmission and gear ratio? What fuel? Max HP RPM? Max Torque RPM?
You only have 24# injectors, basically stock TJ. Probably a stock TJ fuel pump. Probably a stock TJ ECU.
Stock fuel system + stock ECU = Stock power. You could put a 481x and a Lenco in your TJ, with stock fuel and ignition it'll make 200 HP.
Your numbers actually look OK for a mild stroker.jmarsh1082 wrote: ↑June 5th, 2023, 10:24 am Last dyno pull,
STPTrq Max 220.5.
What transmission do you have, and which gear was used for the dyno pull?
Also what axle gear ratio and what size tires are you running?
All of these factors will have a bearing on the dyno results.
BTW, the stock fuel pump is fine.
Hey, thanks for the reply!
I'll try to answer all the questions.
I believe it was a 5th gear pull at 110 mph.
Its a 03 Rubicon so 4:10 stock gears?
33 inch tires.
Running premium fuel.
I have a fuel regulator delete kit with after market fuel pump.
And a fuel regulator.
The jeep has high flow exhaust a bigger air intake I think 63mm. Id have to go look.
AFE air box. Banks headers.
My goal was something like a golen engine hp and tourke.
It ended up costing way more for way less.
Thanks for your guy's feedback.
33 inch tires.
Using 5th gear (NV3550 transmission I presume) with 33" tires definitely wouldn't have helped the dyno numbers! They should have used 4th.
Stock 4.0 engined Jeeps like yours typically put down about 135rwhp so if we assume a 29% drivetrain loss, yours would be making about 240hp & 310lbft at the crank. That's on par for a mild stroker.
