Newbie renix stroker question(s)
Lilblue89xj
Stroker Displacement: 4.0L
Vehicle Year: 1989
Post by Lilblue89xj »
Hello everyone! Phew where to start.
Okay I'm new here so bare with me. I've gone through read a few post and can tell I'm beating a dead horse. Just looking for some direction. What I'm working with is an 89' renix 4.0L, I would like to achieve 4.6 but not sure where to begin. Looks like theres a quench problem, fuel pressure reg/injector and possibly a MAP issue. Besides these issues what else do I need to be considering? I do plan on having the block and head worked at a machine shop. End goal is to still be able to uses as much of the stock options as possible as well as have reliability for wheeling and pulling my overlanding trailer.
My apologize for this seemingly annoying post :)
Re: Newbie renix stroker question(s)
You could do a simple 4.6L stroker build using the following parts:
4.2L crankshaft
4.0L connecting rods
Russ Pottenger's custom.pistons +0.030"
Russ Pottenger's low lift 68-232-4 camshaft
Bored 62mm HO throttle body adapted to Renix intake manifold
2.5" exhaust
22lb injectors
I suggest you contact Russ by PM and discuss your options.
Lilblue89xj
Vehicle Year: 1989
I very much appreciate your input! Thank you for all the information! I was going to buy a stroker kit unless I could find more information on parts and do some figuring of math. I would very much like to keep it on the budget side of things if possible. As far as adapting the ho throttle body is there an adapter plate and what about the TPS?
Again thank you for the information I will look into these parts if you have sources for them send it my way.
Lilblue89xj wrote: March 29th, 2024, 10:08 am As far as adapting the ho throttle body is there an adapter plate and what about the TPS?
The custom route would be best and cheapest.
https://www.rockmodified.com/Tech/TB/tb_perf.htm
Strong Poster
Strong Poster
Post by Russ Pottenger »
Thanks as always for the referral Dino : )
Happy to hook you up Lilblue. Just responded to your PM with my email so I could get some specific and detailed information out to ya.
Thanks,
Russ
Lilblue89xj
Vehicle Year: 1989
Yessir thank you I sent you an email.
