S.A. Gear 1999-2006 roller timing set
Post by dwg86 »
S.A. Gear is making a billet steel roller timing chain for the later model 4.0 engines (1999-2006). Part number 785819R. $98.78 on rock auto. I has 9 keyways on the crank gear for adjustability.
2grimjim
Where's the "any" key?
Vehicle Year: 2006
Vehicle Model: LJ
Re: S.A. Gear 1999-2006 roller timing set
Post by 2grimjim »
This is awesome news! I just got on their website and bough one.
Now, if we could just get a few more cam grinders to make performance cams for the 99-06.
2grimjim
Vehicle Year: 2006
Vehicle Model: LJ
Post by 2grimjim »
Wow. I had no idea that SA had been making these for over 10 years and selling through Titan. They sure did keep it a good secret for a long time. Regardless, I'm glad they're available through Rockauto.
Post by dwg86 »
2grimjim wrote: ↑May 11th, 2024, 8:56 pm This is awesome news! I just got on their website and bough one.
I talked to Bullet cams. They have 90, 1999-2006 cam cores ready to be ground to your custom specs. Cores are made in USA!
Post by dwg86 »
dwg86 wrote: ↑May 12th, 2024, 6:30 pm
The biggest problem is finding a drop in valve spring that will work for lifts over .450. I've about given up on that. I'm looking for any valve spring that doesn't have too much pressure that will work with a stock retainer. Well at this point I'm looking for any spring that will work with a 4.0 jeep, magnum v8, or hemi retainer that I can machine the head to get around 80-85 psi on the seat and maybe 210-230 open at around .480-500 lift. I'm not sure how much can be machined at the valve pocket.
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
I just took 0.100" from my 0630, no issues. Using LS valves, retainers and beehives FWIW
