74 Scout ii 4.0 to amc 727
326Firefighter
Stroker Displacement: 242
Vehicle Year: 1974
Vehicle Make: Internatio
Vehicle Model: Scout ii
Post by 326Firefighter »
I’m in need of advice from those who know or been there done that! I have a stock 4.0 and wanting to bolt her up to my AMC 727 torqueflite. I have searched and found information to use the 42 re automatic flex plate from 91-95 era jeeps.
Here’s the two maybe three things.
1: This is a 96 4.0 (obd2) and had a manual trans.(will my Crank position sensor from the manual work on my 42re flex plate?
2: what torque converter do I choose. Bone stock amc 727 one for a 258? I would like a slight bump in performance in this purchase.
3: any advice on placement of the cps sensor on my bellhousing. Any pictures that one of you guys have where this has been done? Links ect?
I know I can cut a nice spot in the bell housing. What I don’t know is how close the cow needs to be to read the ring thingy.
I know Hesco made one for the crank separate of the trans but 359$🙂‍↔️ woah
Any advice at all would be appreciated !
RoadVanguard
Stroker Displacement: Planning 284ci
Vehicle Year: 1969
Vehicle Model: Deciding
Re: 74 Scout ii 4.0 to amc 727
Post by RoadVanguard »
Hey there! It's awesome that you're diving into this project with your Scout ii. For your first question, typically the CPS from the manual transmission should work fine with the 42re flex plate. As for the torque converter, going for one meant for a 258 with a slight performance boost sounds like a solid plan. When it comes to placing the CPS sensor on the bellhousing, aiming for proximity without touching is key. Cutting a nice spot sounds like a good idea, and looking at some images online for reference can really help. Keep up the great work, and don't hesitate to reach out if you need more advice!
Take a look at auto repair Manchester NH and don't forget to explore healthcare equipment for more details. While you're at it, check out witchcraft for some useful insights.
mpgMike
Vehicle Year: 1995
Vehicle Model: ZJ
Post by mpgMike »
I have a '95 ZJ I swapped a manual into. The crank sensors were different between the 42RE and NV3550. Not sure how that will work for you.
