thickness Head gasket
Jeeper26
Stroker Displacement: 4.6l
Vehicle Model: TJ
Post by Jeeper26 »
Hello, I'm new here. I started building my first stroker. He's going to have it.
- ic944-020
- Rod scat icr40L
- craink 4.2L-3895
- cam 68-232
- head edelbrock 50169
- roller rocker S40196a
- 24lbs injector
- AFE 2.5’’ manufold and exhaust
- Bbk throttle body
I have a clearence deck of 0.026
I'm wondering if I should put a head gasket of 0.040 , 0.030or a 0.027. I entered the information into a calculator.
Here's what it gives me.
I have no problem driving on 91 octane.
What do you think of these numbers?
Which one would you suggest for 91 octane?
Thanks 😊
Jeeper26
Vehicle Model: TJ
Re: thickness Head gasket
Post by Jeeper26 »
Hello, I am thinking of cutting the 0.020 block and putting a 0.040 cometic head gasket.
I think quench is closer to what it's good for. (0.045) What do you think?
But do you think dcr 8.48 is too much for 91 octane? Here are the results.
THANKS
Are you using the stock cast iron heads or Edelbrock aluminium heads? If it's the latter you'll be fine.
Jeeper26
Vehicle Model: TJ
Post by Jeeper26 »
hello, I'm going to use an aluminum edelbrock head. Today I am going to cut the block of 0.020. which will give me 0.005 deck clerance with a quench of 0.045.
Strong Poster
Strong Poster
Post by Russ Pottenger »
I would support your decision to tighten up the Quench.
With a normally aspirated engine running a aluminum head 91 octane I’m generally shooting for a minimum static of 10.5:1
Jeeper26
Vehicle Model: TJ
Post by Jeeper26 »
Hello, I finally decided to cut the block at 0.00 deck clearance and a head gasket cometic mls 0.040. My quench will be 0.040 and my static will be 9.97. I think it will be ok.
Thanks for your help.
GASnBRASS
I think I'll order a "tab"
Stroker Displacement: 4.1 / 250ci
Vehicle Model: TJ
Post by GASnBRASS »
Russ Pottenger wrote: November 16th, 2024, 8:37 am I would support your decision to tighten up the Quench.
I know the dynamic compression is cam dependent, but with 10.5:1 static, what kind of dynamic compression are you aiming for with 91 pump gas?
Strong Poster
Strong Poster
Offhand I don’t know what the dynamic is but the camshaft I’m using is the 68-235-4 but with the lobe separation angle changed from 111° to 114° has worked like a champ with a factory tune and typically with a 24 pound injector
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
