Billet Roller Cams Now Available
Post by dwg86 »
Randy Bobandi
Re: Billet Roller Cams Now Available
Post by Randy Bobandi »
Newcomer is always a step behind ol' Randy lol.
$2K for the cam, $135 for the distributor gear is aggressive! But fair play to him. We need more aftermarket support, so this is excellent.
I'll be interested in seeing his approach to getting the lifters in the block. Whether he machines the block or has a custom link bar setup on the lifters. Judging by the price of the lifters, I think he may suggest machining the block, which is what I did.
Post by dwg86 »
his website shows $915.00 for the cam, $1700.00 total when I add lifters and distributor gear to the cam. It's good to see any aftermarket support for these engines that have been out of production for 20 years.
I've been watching your build. pretty impressive.
I'd love to see a crossflow head. Keep the intake on the same side that it's on and run the exhaust on the passenger side and make a straight shot to mate it up to the factory exhaust. The R&D and casting process I'm sure wouldn't be cheap...and I don't have the money for that.
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
I think you'd have to relocate the spark plug. There's too much needed real estate in that side with the push rods, spark plug and now exhaust as well. But it would be cool to see it
Post by dwg86 »
I forgot about the pushrods being over on that side of the head. I was just thinking about the easiest way without having to make a new intake manifold.
It's a big shame they've only become available almost 20 years since the last Jeep 4.0L engine rolled off the production line.
Randy Bobandi
dwg86 wrote: January 14th, 2025, 7:00 am his website shows $915.00 for the cam, $1700.00 total when I add lifters and distributor gear to the cam. It's good to see any aftermarket support for these engines that have been out of production for 20 years.
Oh I see the $915 now. That's actually a great price.
I also see he mentions no machining required. They must be modifying the tie-bars on the lifters if that's the case.
dwg86 wrote: January 14th, 2025, 7:00 am I'd love to see a crossflow head. Keep the intake on the same side that it's on and run the exhaust on the passenger side and make a straight shot to mate it up to the factory exhaust. The R&D and casting process I'm sure wouldn't be cheap...and I don't have the money for that.
There's really very little advantage to crossflow over looping flow, other than the obvious heat transfer issue and manifold sealing.
Valve placement is what determines overlap efficiency. That's why hemi style and 4 valve pentroof style chambers are basically standard at this point. That's why I'm not the biggest fan of Edelbrock's Jeep head. Why go through all the work of developing and casting an aftermarket aluminum head if it's just a basic replica of the OE design? If the Edelbrock head was crossflow, yet the valve placement stayed the same, the head flow the exact same.
What we need is a hemi chamber, a twisted big block style chamber or maybe a canted valve Cleveland style chamber.
Randy Bobandi wrote: January 15th, 2025, 6:54 pmWhat we need is a hemi chamber, a twisted big block style chamber or maybe a canted valve Cleveland style chamber.
That would also require a redesigned block. Therefore why bother when there's an easier alternative in the form of a 6.4 Hemi V8 swap.
GASnBRASS
I think I'll order a "tab"
Stroker Displacement: 4.1 / 250ci
Vehicle Model: TJ
Post by GASnBRASS »
What would be the difference between Newcomer's tie bars and 505's tie bars, which have a poor track record of self destructing?
When you say you machined the block, what specifically did you do to the lifter bores?
This is a cam upgrade I'm seriously considering, but not if it's a repeat of 505's issues.
Randy Bobandi
GASnBRASS wrote: January 21st, 2025, 12:30 pm
505 was grinding roller lobes onto OE cast iron cams. The issue there was obviously the dramatic difference in surface hardness between the iron cam lobe and the steel roller. The rollers would just smush a giant canal into each cam lobe.
When I refer to the tie-bars, it's simply a matter of getting the pair of lifters into the lifter bores. The Jeep block has reinforcements cast between each lifter bore. Reinforcements that engines like a Hemi or LS do not have.
In order to install tie-bar lifters, the tie-bar design has to be modified. Either a slot in one end of the tie-bar or perhaps a different fastener, something other than the usual rivet.
The other option is to machine slots through the reinforcement gussets in the block. This approach allows for easy install and removal of unmodified tie-bar lifters. Newcomer mentions no machining. So, I'm guessing the lifters he's selling have a modified link bar.
alexfloresaz
Stroker Displacement: 4.9
Post by alexfloresaz »
It has been a while since Newcomer has been taking orders on these Camshafts. Does anyone have pictures of the Lifters he is providing? I assume something similar to the Endure-X Solid Roller Lifters, part # 861-16 Style A, with the 839-L Link Bars. I am really interested, I just don't want to get burned again with expensive parts that are not good.
Straubtech
Vehicle Year: 2006
Vehicle Model: LJ
Post by Straubtech »
The lifters are made by Morel. Tie bar is designed with a slotted end and is attached to 1 lifter. 2nd lifter installed by sliding it into the slot.
Hyd are .700" wheel and have a live axle with a wire lock retaining system. These lifters can take up to .365" lobe lift.
Solid rollers are based on Morel's UltraPro series of lifters and feature a .810" wheel. These come with pressure fed oiling to the needle bearings. They use the same stainless steel tie bar as they hydraulics.
Coated cast gears in both .500 and .530 have been produced and tested on steel billets from 1055 to S7 and have proven no premature wear as tested by the OEM's.
All parts are made in the USA.
Gorilla
Stroker Displacement: 4.0
Vehicle Year: 2004
Vehicle Model: TJ
Post by Gorilla »
alexfloresaz wrote: May 24th, 2025, 8:18 pm It has been a while since Newcomer has been taking orders on these Camshafts. Does anyone have pictures of the Lifters he is providing? I assume something similar to the Endure-X Solid Roller Lifters, part # 861-16 Style A, with the 839-L Link Bars. I am really interested, I just don't want to get burned again with expensive parts that are not good.
There are photos of the hyd lifters on his site in addition to the info below.
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 3 guests
