There a few threads floating around about cam bearing failures in the i6, I've seen them fail in a fully stock rebuild all the way to a performance build, never heard of it on a factory built engine, something goes on when the engines are rebuilt, that on rare occasions will cause the cam bearings to squeeze on out like play dough, I've heard everything from cam walk, low quality bearings, insufficient oiling, too high spring pressure/cam lift, bore alignment, all the threads end with no definitive answer, i myself have had my bearings fail twice and have been doing a ton of research on the issue,for the sake of us jeep enthusiasts let's get to the bottom of this so nobody has to tear down a freshly built engine again
My stroker
Got a 98 4.0 with 170,000 miles from a guy that definitely beat on it, had a knock and needed an overhaul he said, so I bought it because I wanted to build my own performance jeep engine, took it apart Piston skirts were shattered on a few pistons, did a lot of research on parts and what to do to build a stroker before hand here's my original build
Forged pistons, 4.2 crank, 4.0 rods, bullet racing cam stage 3, 217/223, .484/.494 , spring rate 120/310, clevite coated cam bearings, slightly larger stainless steel Manley valves and harland sharp roller rockers, stock timing chain, running 10w-30 oil and a standard oil pump, ported the head and manifold, ran great for about 1 year and 10,000 miles
Until one day I heard a ticking noise, decided to drop the pan to inspect and found my cam bearings squeezed out, I thought I did something horrible wrong so I took it to a professional engine builder, he'd did absolutely nothing different after telling him my concerns, other than putting in a smaller lift cam and lower valve springs, wich is what i thought was the problem, dont know the cam or lift or duration, and a hv oil pump, along with other disappointing workmanship and customer service but he did have a good reputation but still was not impressed
7500 miles after that my oil pressure began to act funny, would drop and shake around sometimes, being an old jeep yj I wasn't terribly concerned but decided to take a look anyway, the cam bearings had squeezed out again, this is where I really decided to get into it, I called everyone that built 4.0s and engine shops in general, I decided to remove the spring bolt and install a solid pin, run high quality ACL bearings, had my new cam polished to allow .025 clearance, and run 20w-50 oil, was sure this would do it...
The new comp cam I installed is such poor quality that the distributor doesn't line up properly, the pin you place in the distributor to install it, it won't mesh with the cam because the gear on the cam is ground offset a few degrees, yes the cam is degreed properly, after 200 miles of driving I decided to remove the distributor in hopes of rotating that geat 180 to allow it to line up properly, it was only off by a degree or 2, but upon removing I found the distributor gear eaten up and the cam gear showed some damage too, turns out 20w-50 was too much for the oil pump to handle and it wore out the Gears, my oil gauge showed a drop of about 5psi, ( I idles ad 60 while warmed up) when reving, pretty sure the pump was cavitating
So where am I at now, I have a new gear coming for the distributor and have gone back to 10w-30 oil, once I install the gear I pray that the cam will not eat itself from the damage of a mistake that I shouldn't have made, but hey, I was following to professional jeep engine builders orders, I hope it doesn't fail but if it does I hope it lasts long enough to see if I have fixed the bearings issue, I want to here everyone's input on this subject, it's problem that shouldn't happen and has no clear solution, these engines have an amazing reputation for reliability and I know adding performance parts takes that away but we are smart enough to figure this out and help the next guy from going through this stressful and expensive problem
Cam bearing failures, let's finish this
Jeepking1995
- Vehicle Year: 1993
- Vehicle Model: Yj
Re: Cam bearing failures, let's finish this
I hope all works out for you this time. I'm confused...what cam are you running now?
The spring rate isn't terribly high, but I'm not so sure you need springs rates that high on a hydraulic flat tappet cam...unless you plan on running it at high RPM's. The factory rev limiter is set at 5300, so you'll have it tuned or have an HP tuner MPVI, you're not turning it any faster.
Jeepking1995
- Vehicle Model: Yj
Forgot to mention the cam in it now is a comp 68-301-5 .488/.507 , 205/213, using the same springs from the bullet cam because the cams are kinda similar, but just using what the manufacturer recommended, the springs on the 2nd cam where a smaller diameter then the original ones I put on, wasn't planning on making high rpm just power
- gonridnu
- Vehicle Year: 1989
- Vehicle Model: XJ 2 door
Hello, my name is Loren. I owned an engine shop and was the national sales manager for a valve train company. It was my job to fly around the country giving seminars to NASCAR guys about valve train geometry. You can read about my stroker build under "Gonridnu Stroker" in projects.
The reason it is hard to nail this down is because there are multiple modes of failure, almost all the result of improper build. The guys that missed something have a hard time catching it the next time around, or difficulty diagnosing the failure from broken parts due to lack of experience.
A cam bearing should never squish out. In comparison to a rod or main bearing they take a lot less load. We refer to cam bearings as "low load bearings" as they mostly see spring pressure and combustion pressure on the exhaust valve only when it is opening. It requires a 2 pound sledge and a cam bearing tool to drive cam bearings into place. Perhaps if the fit was super loose you would see one migrate, but again that is a build mistake.
When fitting cam bearings it is not unususal to "wittle" or "shave" them. Some guys use a deburr knife on the end of a long stick and some guys take old cams and machine a notch in them, then turn the cam while driving it in, thus shaving the required amount to get the cam to fit. Someone could potentially overdue it, but it's tedious so that doesn't really happen.
If an engine is "squeezing" the cam bearings out like silly putty it will almost certainlky be mechanical interference somewhere in the valve train.
I don't remember anymore if these engines priority oil the mains or the lifters. With 60 psi at idle your main/rod bearing tolerances are likely too tight. Oiol clearance should be about .001" per inch of diameter of the journal. Would this happen to be a high volume pump?
mpgMike
- Vehicle Year: 1995
- Vehicle Model: ZJ
I'm rebuilding a small block Chevy 350 in the shop for a customer. It took 4 sets of cam bearings to get a set that actually blueprinted out. Three of the 4 sets were Clevite (owned by Mahle now), and one was from Amazon(?). Some of the bearings were the wrong OD, some the wrong ID, some had improper oil holes. If a major reputable manufacturer can get the venerable SBC parts wrong, is it possible that the obscure Jeep 4.0 stuff could also be wrong out of the box?? All I can say, is any engine builder that does not blueprint EVERYTHING in this day of Chinese parts is inviting a failure. Whatever failed would have probably shown up with proper measuring and inspection (blueprinting). Side note; I have about 5k miles on my 4.6 stroker, and am using Comp Cams camshaft and lifters. Low lift for grunt, so using stock springs. No issues so far.
