Turbo time
PSR 7982G - Dual V-Band 1.15 A/R
06 LJ Randy Rebuild
Randy Bobandi
Re: 06 LJ Randy Rebuild
- D'sJeepWrld
- Stroker Displacement: 4.0
- Vehicle Year: 2005
- Vehicle Model: LJ
Thats a bad unitRandy Bobandi wrote: ↑December 12th, 2024, 8:34 pm Turbo time
What made you decide using pulasar over the Forced performance turbo ? I know PSR makes some great stuff for a better price but not in this case when you compare the FP turbo im looking at to your current turbo!
I see the compressor wheel has some curve over the FP and a the capability to run a turbine speed sensor from what im looking at ?
Im just excited to see this jeep be built and ripping, Can't imagine the feeling being the one building it
Randy Bobandi
I purchased the Pulsar unit during the Black Friday sale, so it ended up costing exactly $1000. Something to keep in mind is that Pulsar turbos come with all necessary weld flanges, gaskets and fittings. Pulsar's price is actually better considering all the parts that come with the turbo.D'sJeepWrld wrote: ↑December 23rd, 2024, 4:52 pm
Also, Pulsar offers way more turbine housing options. Their G series lineup is compatible with Garrett & Tial stainless turbine housings if you want to go stainless in the future.
If I felt like blowing more money on it, I would've went with the new Xona Rotor 8082. Xona is one of few manufacturers that design, cast, machine and assemble all here in the US.
Most US based turbo companies still purchase all castings from China. Precision, China. FI, China. There's no escaping Chinese turbos and Pulsar is known as the best of the bunch.
- D'sJeepWrld
- Vehicle Model: LJ
Right on man,Gotta love the black Friday deals ! Took advantage of it for a Savvy tummy tuck for my Lj
And gotta love PSR with their Interchange-ability! I knew a bit about them since I've seen BMW guys get a Psr core and run their precision coldside/hotsides due to their precision unit failing and so on&so fourth!
Also that's good to know about on the G series turbos,Didn't know that !
Once the time comes i might be running a PSR 3582 .82Ar stainless dual vBand deal! Should be good for my application But I'll see
And marry late Christmas.....or happy new years
Randy Bobandi
Concerned about the manifold sealing under pressure, I decided to O-ring the intake flange. Don't even ask how I did it, it took weeks to do it. Way too much time on the dremel. The header flange was much easier to resurface flat and will seal perfectly with RTV. This intake manifold, not so much. After O-ringing it, it seals so well the plenum will explode before the flange leaks
Exhaust manifold was a project as well. Rather than spending the 2 grand or whatever ARH wants for an inline 6 header. I took the Flowtech header ($150), cut off the 1 1/2" primaries and welded in, matching the bends in 1 3/4" tubes from an assorted 1 3/4" header tube kit. Collectors feed 2 1/2" tubes and merge into a 3" V-Band. It's basically a custom 1 3/4" header. Sandblasted, Cerakote and wrapped with fiberglass and embossed stainless sheet. This stainless shield is fastened with stainless rivets like a dang space ship.
- D'sJeepWrld
- Vehicle Model: LJ
- D'sJeepWrld
- Vehicle Model: LJ
So how's it going with the build
mpgMike
- Vehicle Year: 1995
- Vehicle Model: ZJ
Randy, you added a header wrap, but left lots of bare pipe. Why? I would have extended the wrap to every inch of pipe I could wrap.
