Injector confusion
lazyxj
Injector confusion
Here is what I'm building
2001 XJ California emissions
4.6 Russ Pottenger short block
Russ Pottenger 0630 P&P, with big valves
CompCam 68-231-4.
Ported late-model intake manifold
62mm TB
Banks header
My build looks very similar to Dino’s 4.6L 268-HP low-buck stroker, which specifies a 24-lb injector.
Problem is, almost every build sheet specifies 24-lb injector, regardless of the horsepower rating, no matter if the projected output is 240 or 268-hp.
Logic would seem to dictate a larger injector for a higher output engine.
According to the injector size formula, on Dino’s site (and many other sites), a 268-HP 4.6 should use 27.9-lb injectors
Injector size (lb/hr) = (horsepower x 0.5)/(no.of cylinders x 0.8)
Let’s say my engine will produce a conservative 260-HP
(260 X .5) (6 X .8) = 27.2-LB
So, should a 27-lb @49psi injector be used or am I missing something?
Are the formulas invalid or do they not take into consideration other aspects to the build? Black magic maybe?
Something like this?
https://fuelinjectorconnection.com/coll ... r-27lb-set
CompCam 68-231-4.
62mm TB
Banks header
Re: Injector confusion
I did indeed specify the Ford 24lb injector on more than one build but note that in each case, the fuel pressure (and injector flow) is different for each application. On the Jeep I6 you'll need an injector flow in lb/hr (adjusted for fuel pressure) that's 1/10 of the expected crank HP.lazyxj wrote:My build looks very similar to Dino’s 4.6L 268-HP low-buck stroker, which specifies a 24-lb injector.
The Ford Racing 24lb injector is rated to flow ~24lb/hr at 39psi. On a 49psi injector rail it'll flow 26.9lb/hr which is exactly what you'd need on an I6 engine in a '96-'04 Jeep that produces ~270hp. The injectors you referred to in the link would also work.
Stroker Build Stroker Recipes
lazyxj
Thanks Dino for confirming what I had hoped I understood.
Like so many forums, the core group of knowledgable people is shrinking, as they move onto new interests and hobbies.
Thanks also for continuing to participate in the forum...even if you do own a Ford.
I own a Ford too, used to pull our Jeep around the USA.
https://www.flickr.com/photos/lwade/alb ... 7829693253
Total agreement with you Larry.lazyxj wrote:Thanks Dino for confirming what I had hoped I understood.
Dino's continuing participation in the Jeep community is truly appreciated
Yeah, but not just any old Ford.lazyxj wrote:Thanks also for continuing to participate in the forum...even if you do own a Ford.
http://www.angelfire.com/my/fan/Mustang2006GT/Home.html
Thanks Russ.Russ Pottenger wrote:Dino's continuing participation in the Jeep community is truly appreciated
RockyMtn96XJ
Is there any harm in buying injectors that are "too big" for my build? As in, can I use the 26.9lb injectors in my ~245hp modified poor man recipe?
Just curious, so I know what my options are when buying injectors next week. If I find bigger ones I just want to know If I can use them or if I need to find the "24.x lb" injectors.
If I use larger ones, would I need an adjustable voltage regulator for my MAP to turn the fuel down at high RPM?
'96 Sport 4 Dr 4.0 AW4 231 D30 8.25, 4.5", 5100's, A/A SYE, '99 Intake, 703's, header, 2.5" FM 40, 31" KO2's. DD
'01 Camaro SS modded
(77k mi Sept. 2024)
'18 Durango Black Top: Family Ride
Retired Air Force
Retired Air Force
There's no harm in buying bigger injectors than you might really need as long as you have an ECU that can be reprogrammed to reduce the injector duty cycle. Luckily yours is OBD 2 so that makes it possible.
RockyMtn96XJ
Thank you for the info.
(77k mi Sept. 2024)
Retired Air Force
Retired Air Force
RockyMtn96XJ
I need a reminder now...
In my (late build) '96... no fuel rail regulator.... would I need the DIY MAP voltage regulator for my injectors? I dont want to mess with tuning the ECU if i dont have to. Are there any other "quirks" I should remember about with the fuel pressure and all that?
But..... I think I saw the voltage regulator is only needed up to 1995, or for models with the regulator on the fuel rail (including early build 1996 models).
Or will the ECU auto adjust for fuel/air in my case? (OBD2 and fuel tank regulator, larger injectors, a lot more air flow)
Facts: poor man stroker, typical cam swap, opened intake and exhaust ports on head, and air intake about 1.5" deep (port matching) but header left alone) , big throttle body with opened intake.... the usual stuff. Just wondering if I need to do anything I have forgotten about regarding fuel since its been a DANG year since I started this project.
I can give the info on the injectors I bought if needed. I'll have to get home and look at what I bought because I forgot, but I know they should be correct for my build. I highly doubt I purchased injectors that were slightly under the calculated requirement. I'm sure I bought the size that is just above the calculated requirement.
Thanks for the reminders.
I'll start a new thread in the project section once I'm done and can spend time posting pictures and useful info on my stroker build.
(77k mi Sept. 2024)
Retired Air Force
Retired Air Force
mpgMike
- Vehicle Year: 1995
- Vehicle Model: ZJ
Here is my experience with my '95 ZJ (no fuel rail pressure regulator) with a 4.6 stroker:
Stock injectors ran just fine. Wanted to "upgrade" to the Ford 12-hole. Stock flows (I think) 21 lbs/hr, while the Fords flow 24. (Even if the numbers are wrong, the relationship is right.)
It would run rich on cold start until the O2 sensor warmed up, then within seconds lean back to normal. The more I drove it, the better the stock PCM seemed to work with the larger injectors. Had one die, replaced it. Had another one die and..
"Upgrade" to GM EcoTech 2.4 FlexFuel E-85 compatible 12-hole injectors -- which flow at 27 lbs/hr. So at this point, I've gone from 21 to 24 to 27. It took much longer for the stock PCM to adjust, but it now starts and drives just fine.
Note: I have been toggling back and forth between the stock PCM and rusEFI UAEFI stand-alone. I've mostly used the stand-alone for ignition control, as I have 6 individual GM LS coils for it. I swapped the NB O2 for a Bosch 4.9 LSU and took control of the fuel. That lasted about 1 tuning session before I lost injector #4 driver. Put it back to stock control. I'm putting together a replacement, but with flyback diodes on the injector drivers.
RockyMtn96XJ
That sounds fancy haha....
I have these injectors
0280155715 24LB 250cc Compatible with Ford Pontiac Chevy LS1 EV1 5.0L 5.7L V8
Soooooo you're saying my ECU will learn how to use the injectors....???
(77k mi Sept. 2024)
Retired Air Force
Retired Air Force
mpgMike
- Vehicle Model: ZJ
Yea, pretty much. It's all about the LTFT% Long Term Fuel Trims. It takes several thermal cycles to get them adjusted. With OBD II you can actually see where they're at with a scan tool capable of reading Data Stream. LTFT% values are arranged in an X-Y Table, so they change around on your scan tool as you drive into different Table Cells. The STFT% (Short Term Fuel Trims) will change as you drive, but they're "live" and dynamic. Over time, the STFT% influences the LTFT%.
RockyMtn96XJ
makes total sense.
I want to learn how to tune. Probably not this jeep, but my Camaro SS....
Thanks for the info!!
(77k mi Sept. 2024)
Retired Air Force
Retired Air Force
Gorilla
- Stroker Displacement: 4.0
- Vehicle Year: 2004
I was pretty busy at the time of this discussion, but stepped up from stock to ford performance 24lb injectors on my TJ while still running 4.0L with Edelbrock head, 1.7 roller rockers. I tuned them to shorter pulsewidth and got the LTFTs stable at +/- 1%. This helps, but doesn't tell you what it'll do on wide open throttle with power enrichment (PE). You need a wideband O2 sensor for that which I also have.
Then you can dial in both the base fuel map and the PE. It's not difficult. You're just taking the logged LTFT and multiplying the coresponding sections of the fuel pulsewidth table to adjust it. If LTFT in a cell is +7 (7%), you multiply the pulsewidth in the base map by 1.07. If -7 multiple by 0.93. Go drive 20 miles or so with the new tune, log it again and see where the LTFTs land. Rinse lather repeat until you get into +/-3 on all cells. WOT on the wideband is a bit different, but LTFT on adjacent cells point you in the right direction on base map, then you can dial in PE to get the target AFR under load. 12.8:1 seems to be good with this platform.
