Compression Calculator Update - Version 2.0 Now Live!
Check here for most things forum related... NOT stroker related!
The Compression Ratio Calculator has been completely redesigned and upgraded with several user-friendly improvements:
What's New:
  • Smoother Performance - Calculations happen automatically as you type
  • Camshafts - Added a few more and validated specs of existing ones.
  • Mobile Friendly - Actually usable on a mobile device!
  • Improved Print View - Cleaner layout and better formatting when printing your results
  • Keyboard Navigation - You can now tab through all preset and camshaft selections using your keyboard
  • Form Reset - Added a reset to defaults button
  • Better Error Messages - Clear, helpful feedback if you enter invalid values (no more silent failures)
What You'll Notice:
  • Completely new look!
  • Collapsible Sections
  • The calculator validates your inputs and tells you exactly what's wrong if there's an issue
  • Results update automatically after you stop typing! No need to hit the calculate button
  • Print output now shows all your selections and specs in a clean, professional format
Nothing Changed:
  • All the same calculations and accuracy you're used to
  • Same presets
  • Your favorite camshaft specs are all still there
Everything works exactly as before—just better!
Let me know if you have any questions or notice any issues. All suggestions and feedback are welcome!
Re: Compression Calculator Update - Version 2.0 Now Live!
I found a bunch of issues with the way we are validating form fields in this new version. It was almost unusable unless you got each field correct.
This should be fixed now. I have been testing the hell out of it and it seems to be handling everything flawlessly now.
As always if you see something, let me know so we can address it. Hopefully most of the bugs are behind us now.
Thanks!
P.S. Don't forget to clear your browser cache!
Found another issue that would only affect Samsung Mobile devices (using Samsung Keyboard)
Samsung's default keyboard has issues interpreting the constraints on type="number" inputs. It sometimes "greys out" the minus sign (-) and decimal point (.) buttons based on its own interpretation of what the field allows, even when those characters are valid.
This should be fixed now. Please clear cache!
Thanks @Sly-Jeeper for the reports!
TR1Hemi
Post by TR1Hemi »
Changing rod lengths does change quench, all other thing being equal. It requires the user to do math. The whole idea of the calculator should be zero math. Newcomer has a 5.9 rod allowing stock pistons without milling for zero(ish) deck.
TR1Hemi wrote: ↑November 9th, 2026, 5:00 am Changing rod lengths does change quench, all other thing being equal. It requires the user to do math. The whole idea of the calculator should be zero math. Newcomer has a 5.9 rod allowing stock pistons without milling for zero(ish) deck.
You're right that changing rod length changes where the piston sits at TDC, and with it deck clearance and quench. Your Newcomer point checks out too: their 5.900" rod puts a stock-style piston 0.025" higher than the 5.875" 4.2 rod, which takes you from roughly 0.035" in the hole to about 0.010" or less without milling, depending on the piston.
The calculator is built the way the established ones are, though. UEM/KB's calculator takes deck clearance as a direct input, measured from the top of the block to the flat of the piston, with a negative number when the piston sits above the deck. Rod length only enters the dynamic estimate. Ours works the same way: deck clearance is typed in, and rod length only affects dynamic compression.
The reason is that rod length alone can't tell you deck clearance. You also need piston compression height, and pistons sold as stock 4.0 replacements vary:
  • OEM is about 1.601"
  • Summit lists 1.581", 1.585" and 1.592" options (the Sealed Power W677AP is 1.585")
That's up to 0.020" of spread, nearly as much as the Newcomer rod changes. If the calculator recalculated deck clearance whenever the rod changed, it would quietly give wrong quench and static compression for a lot of builds, and be way off for strokers on custom pistons like the KB944.
That said, you have a point about not making people do the math, so I'm planning to:
  • Add an optional deck clearance helper next to the field. It pulls stroke and rod length from the form, takes piston compression height (with quick picks) and block deck height (9.450" stock, minus any milling), and fills in Deck Clearance as an estimate. A measured value still wins.
  • Allow negative deck clearance for pistons that sit above the deck. The field currently rejects it, but the math already handles it.
  • Add a 5.900" (Newcomer) quick-fill next to the existing 5.875" link.
Thanks to some good feedback here about rod length and deck clearance, I've made a few updates to the calculator. The math hasn't changed. These make it easier to get the right numbers in.
New: Estimate Deck Clearance from Your Parts
Right under the Deck Clearance field there's now an optional estimator. Pick your piston's compression height (pin height), and it works out where the piston sits at TDC using your stroke, rod length and block deck height. You can also enter how much has been milled off the block. Click "Use This Value" to put the result into Deck Clearance.
  • Quick picks for compression height: stock 4.0 (1.601") and common replacement pistons (1.592" and 1.585"). Check your piston's spec sheet if you're not sure.
  • It tells you whether the piston ends up above or below the deck, and warns you if the piston would hit the head.
  • It's an estimate from part specs. If you've measured your deck clearance at mockup, use your measured number.
This means swapping rods or a crank no longer requires doing the deck clearance math yourself. For example, a 4.2 crank with 4.2 rods and a typical replacement piston ends up roughly 0.035" in the hole without milling. The Newcomer 5.900" rod brings that down to about 0.010".
Other changes
  • Newcomer 5.900" rod quick-fill link added next to the 5.875" (4.2L) rod link.
  • Negative values on phones: iPhone number pads don't have a minus key, so there's now a ± button next to Deck Clearance, Dome/Dish, Advance/Retard and Altitude. Use it to enter a piston above the deck, a domed piston or a retarded cam.
  • Piston above the deck: enter it as a negative Deck Clearance.
  • Engine presets only fill in bore and stroke. Remember to set your rod length and deck clearance to match your build.
  • Phone display fixes: the results bar that follows you down the page now fits on phone screens, quench is no longer cut off, and the page no longer zooms in when you tap a field on an iPhone.
If anything looks off or you have a combo the calculator doesn't handle well, post it here and I'll take a look.
TR1Hemi
Post by TR1Hemi »
I could not remember how the old calculator handled those things. We live at 2850, our friends house a 10 min drive away is 3000 feet, and we rarely take the Cherokee east, but we do head west to Cheyenne and Laramie. 6000-9500 feet so building a stroker is easier for us, lots more options. We have a good extra half compression point we can add.
Thanks for keeping up with improvements!
TR1Hemi
Post by TR1Hemi »
The stock rod 6.123 option is not clickable. Like the 5.875 and 5.9 options are.
I play around with it quite a bit.
A complete reset to stock 4.0 settings would be nice.
The compression height for the forged Icon pistons for long rods would be a nice add. 1.300" ish if memory serves.
1991-1998 OEM cam specs could be added, though they may be close enough to the 99+ to just lump them together?
TR1Hemi
Post by TR1Hemi »
Looks like the Icons are more like 1.353".
Thanks for the feedback. These are all in now:
  • The stock 6.123" rod is clickable now, and so is the stock 0.0215" deck.
  • There was already a reset button at the bottom, but it was easy to miss. It's now called Reset to Stock 4.0L.
  • Added the Icon pistons to the deck clearance estimator: 1.353" (IC944) and 1.363" (IC10181, the newer replacement).
  • Found a mistake while looking at the stock cams. The 1999-2004 OEM cam was missing the roughly 7° of retard it has from the factory, so it was showing dynamic compression about 0.3 too high. That's fixed and relabeled 1998-2004 based on the factory service manual. If you used that cam before, re-run your numbers.
I couldn't find the valve timing for 1991-1997. If anyone has a 91-97 factory service manual, can you check whether it lists intake opens 12.4° BTDC and closes 60.9° ABDC? If it matches, I'll add those years to the stock cam.
