I think the big name in this is Somender Singh.. I would only gloss over his site as it reads like an infomercial.
http://somender-singh.com/content/view/68/49/
I'd prefer Vince from the Sham-wow commercials, that's a spokesman that comes across pretty slimySilverXJ wrote:On his site he does tend to contradict himself a lot.. also.. in the FAQ he recommends a quench of .070 over .040.
It just really bugs me that this guy's site reads like its an infomercial. Like Billy Mays needs to read it.
You would be amazed at what will work. I have seen many sins committed on engines by "rebuilders," and then had to fix them. Chainsaw finishes on decks of blocks is fairly common.1bolt wrote:
Basically would you deck your block with a belt sander? Do a valve job with with a drill press? Of course not, because you know you need more precision than that.
Possible, but I don't see how one could verify that.Alex22 wrote: Just thought of this as I was typing. Could the trough act to separate the quench area into two pockets and creating swirl in the chamber?
That just shows how out of touch you are with current performance trends. What you need to realize that the more the product name butchers the english language the more power it provides.... also stickers add hp, as I am sure you know. However, if you combine the butchering with the stick you get a double power boost.1bolt wrote:Powre Linz and Powre Ringz... I bet I'm not the only person who finds the believability of a mod to be inversely proportional to the amount of intentional misspelling... Using Z's in place of S' alone is worth -9 points on my personal 10 point scale of skepticism, forget about "PowRE".
General rule is 1 HP per square inch of stickerSilverXJ wrote:also stickers add hp, as I am sure you know.
