Yeah... casting.. they aren't cast.. lol.. but i know what you mean. Very pretty piston. The pistons, the timing set and my roller rockers are all pretty... but won't be seen. Blah. I guess beauty really is on the inside... LOL.Mgardiner1 wrote: LOVE the way those pistons look. They look more "refined" then the H802's i got (smoother castings, better machined finish)
I assume you are supposed to groove the lifter bores from the bottom? Did the tool come with good instructions on how to use and where to cut the groove? If you can, please take before, maybe one or two with the tool installed, and after pics.
The tool.. you insert it from the top of the bore, and position the knife so it is just outside the bottom of the bore. Then the stop (t-part) is adjusted to take up slack. Then one of the screws on top is turned to extend the take up part (silver foot looking thing). Once it is in position and secured you turn the screw on the blade which draws the blade up into the lifter bore.
As for as where to locate it in the bore it doesn't specify, but it makes it out as you position the blade in line with the oil hole as the instructions say that the blade screw will turn free once it hits the oil hole. However I don't know if that is the idea position as I am not sure that it is over the cam and will drop oil before the cam rotates under the lifter. I may change that it directly over the cam, but comes up to the level of the oil hole. If the cam lobe was centered in the bore (which it isn't), I think the ideal position would be the far passenger side of the block (cam side). However, since the lobe is offset I believe the ideal position for the cut to be directly over the lobe, offset from the far side.
The directions are less than stellar.
   (max number of smilies 10?)
