cam sensor on coil pack motor
rig49jeep
Vehicle Model: TJ
Post by rig49jeep »
Anyone know how to stab “distributor” which is just has a cam sensor on it, on a coil pack motor. I just got my 4.6 back and I don’t know where to set it. It’s in a 2000 TJ.
yuppiexj
Re: cam sensor on coil pack motor
Post by yuppiexj »
You'll need a toothpick
http://motorage.search-autoparts.com/mo ... rticle.pdf
from this thread.
viewtopic.php?f=8&t=482&hilit=toothpick&start=15#p6151
rig49jeep
Vehicle Model: TJ
Post by rig49jeep »
OK to TDC compression, toothpick the sensor, line up the oil pump and gear and slide it in with the wires to the firewall. I can see clamp marks so I should be good there. The only question I have left is there only one way the tooth pick can go?
yuppiexj
Post by yuppiexj »
I found a better pic
http://www.askamechanic.info/askamech2/ ... 0holes.JPG
There is a hole in the vane and a hole in the housing line them up, and stab a toothpick through both of them to hold it in place. tighten the bolt, you should be ready to rock (crawl)
Here's a blog version with better quality pictures.
http://www.askamechanic.info/askamech2/ ... iew/36/46/
Using that ford explorer coil pack isn't really a bad idea. I was planning on going to coil on plug when my coil died or I got around to it, but that might be a better idea. I'm getting sick of man handling that rail out of there when I want to remove spark plugs.
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 1 guest
