306.5in stroker
amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: 306.5in stroker
hasnt the difference in strength been discussed many times as well? unless i missed something, both cranks were supposed to be identical in strength.
ARH
Re: 306.5in stroker
What KOH team are you building this for? I'm not familiar with Heartland Offroad, but I'm thinking Midwest?
Oh, and pictures of the motor build?
'86 XJ - 150/AX5/207 - RIP
'91 XJ - 242/AW4/242 - RIP
'88 XJ - 242/BA10/231
'93 ZJ - 318/46RH/242
heartlandoffroad
- Stroker Displacement: 4.7 turbo
Re: 306.5in stroker
I don't need to read any thread to know the max RPM of a Jeep engine. I've built several strokers with this crank and have never had a breakage problem. In fact my personal stroker is a 4.7 turbo that makes 437hp and 620ft of torque and shift it at 5800 all the time.Plechtan wrote:The eight counterweight crank and 5600 rpm? Maybe you should read the "max rpm of jeep engine" thread.
heartlandoffroad
Re: 306.5in stroker
They are in the LCQ Alan Grady and Thomas Grady from Rockford Ill.ARH wrote:What KOH team are you building this for? I'm not familiar with Heartland Offroad, but I'm thinking Midwest?
I'm located in Troy Mo. we've been here sense 1996
heartlandoffroad
Re: 306.5in stroker
Accually I didn't have to make it much bigger but I did work for a LOOOONG!!! time on the runners and played with the seat radius allot so to keep the speed up. The piston demand on this engine is going to be very hi with it being a 4.200 stroke so I'm hoping air velocity will still be hi to keep the low end torque up at a lower RPM.1bolt wrote:I for one will be real interested to see the torque curve of such big ports. 280CFM is 30 more than I've seen from any other head porter on an iron head, and 200 CFM exhaust is just insane... Did you get into the epoxy to get that kind of flow? Did you hit any water jackets.
1bolt
Re: 306.5in stroker
What cam specs are you going with?
Simon
Simon
SIXPAK
- Stroker Displacement: 280
Re: 306.5in stroker
Hey heartland, we had the same hopes when porting my current head but lost velocity. Ended up going back in and adding epoxy in some non critical areas to regain the TQ. It did not end up hurting the flow numbers at all.
heartlandoffroad
Re: 306.5in stroker
Bullet built me this cam
------------------------------------intake--------exhaust
Duration at .050-------------------236------------242
lobe lift---------------------------.3400-----------.3400
separation----110---------------op---cl------------op-----cl
timing events at .050----------12---44-----------55-----7
duration at-------.006-------------282---------------292
gross valve lift--------------------.544--------------.544
degree intake lobe to----------------------106
Here is a few pics I'll have some more soon.
Alex22
Re: 306.5in stroker
Excellent build.
I wish I had the budget for custom rods, about how much did those run you and if you don't mind sharing, what is the actual rod journal size?
~Alex
~Alex
heartlandoffroad
Re: 306.5in stroker
Thank you for the compliment.
I believe the rods are 1300.00 a set.
The big end size is 1.771 with a 1.117 width
6TIME
- Vehicle Year: 1993
- Vehicle Make: JEEP
- Vehicle Model: CHEROKEE
Re: 306.5in stroker
Wow! Very impressive build. I'm anxious to hear about the dyno results of this motor. Keep us informed!
Alex22
Re: 306.5in stroker
Cool. We have been using the Honda Civic rod sizes on a lot of our road race 289 and 302 Fords.
That is a lot cheaper per set than I had expected for the rods considering their production parts are about 800 per set.
Re: 306.5in stroker
Impressive. I have heard a lot of people use honda rods and the like on V8s, but not thing on the I6 until now. Good luck and keep us updated.
Plechtan
- Vehicle Model: Comanche
Re: 306.5in stroker
Well I looked around, and you can get a 5.9" rod for a MITSUBISHI Eclipse ( 4 banger) that has a 1.115 BE width ( jeep= 1.060 be) and a BE diameter of 1.771. so if you wanted to offset grind you crank .3", you could use these rods and they would only cost you about $100 each. It does use a .826 floating pin, so you would need to go with custom pistons, but at least you would not need custom pistons and custom rods. Custom pistons at about $100 each is better that custom rods at more than $200 each.
Peter Lechtanski
gremlinsteve
Re: 306.5in stroker
my kind of build.. ill be watching for the end results.
nice cam specs also.
have you put any thought into cryo treatments and or at least running the parts through polydyn and get the coatings?
steve-o
steve-o
