If it's a crank kit for a 258, the mains won't work. You need main bearings for a 4.0.Exos wrote:Found a 12 cw crank for 225$ CND including rod and main bearings. I'm going to pick it up this week or next. I will be removing my cylinder head tomorrow, and probly the pistons, rods and crank too. I'll try to post some pics soon.
cylinder bore question
Re: cylinder bore question
- John
Check this link, Flash and I kinda
but you will find answers.viewtopic.php?f=5&t=199&p=2124&hilit=rod+length#p2124
but you will find answers.viewtopic.php?f=5&t=199&p=2124&hilit=rod+length#p2124John
Exos wrote:Ok, another question comes to mind : After decking the block, and when all is ready to assemble, will I need stock length pushrods, or shorter ones? How do I measure the exact length I need? Is it OK to put shims under the bridges if my pushrods are too long?
I haven't built mt engine yet, but from what I've read, you will need shorter pushrods or shim the rockers. Either is OK.
- Exos
So if I understand correctly (I'm french speaking, so sometimes I don't get everything...), I need to buy a "check pushrod" and have custom ones made?John wrote:Check this link, Flash and I kindabut you will find answers.viewtopic.php?f=5&t=199&p=2124&hilit=rod+length#p2124
- Exos
Stock pushrod length is 9.640-9.660... So let's say 9.650. If I deck the block to zero, I should be shaving around 0.030. So 9.650 minus 0.030 = 9.620... now, Hesco sells pushrods of 9.622 length for the 4.2l. Would'nt that be the perfect match?
http://www.hesco.us/shop.asp?action=det ... catId=7758
- Exos
Anyone?
In the meantime, here's my parts list so far :
Block : got it (93)
Pistons : need KB944 0,060 oversize
crankshaft : 3214723 (12 cw) got it
crankshaft spacer : 1 cm (from old pulley?) or cut crank 1 cm (done, crank cut)
crank rear main seal, oil pan seal : need
rods : from block if good
rod and main bearings : with crank
Pilot bearing : need pilot bearing with sleeve 53009180AB (1.82" OD x 0.75" ID)
Fuel injectors : need (ford racing 24 lbs?)
camshaft + bearings : need (comp 232-4?)
harmonic damper : need one
freeze plugs :need
head gasket : need Mopar Performance P4529242 / Victor Reinz Dana 5713----0.043" or Fel-Pro 9076PT----0.043"
timing gear and chain : reuse if good? Or kit with cam
Lifters : need (comp?)
oil pump: reuse
Flywheel and pressure plate : need
cylinder head : got it , valve job needed and diy porting
pushrods : need some (hesco 9,622?)
valves : reuse if good
valve springs, retainers and locks : need some (comp kit?)
valve stem seals : need some (comp kit?)
rockers : from block if good, Yella Terra roller rockers if I win lottery. (Crower stud mounted an option?)
upper and lower gasket set : need
other mods
exhaust headers + cat back (borla, gibson, rugged ridge?)
63mm throttle body: http://www.strokedjeep.com/tbody.html
throttle body spacer: http://www.strokedjeep.com/tbody.html
piggy-back fuel controller : http://www.alamomotorsports.com/apexi/safc.html#safcneo
4.56 gears
Block : got it (93)
freeze plugs :need
oil pump: reuse
other mods
4.56 gears
Exos wrote:Stock pushrod length is 9.640-9.660... So let's say 9.650. If I deck the block to zero, I should be shaving around 0.030. So 9.650 minus 0.030 = 9.620... now, Hesco sells pushrods of 9.622 length for the 4.2l. Would'nt that be the perfect match?
http://www.jeep4.0performance.4mg.com/valvetrain.html
At the very bottom Dino lists different pushrods available. Also, keep in mind that your head gasket thickness will play a part too. Custome length pushrods are also an option. I would see if your machine shop would let you borrow a length checker push rod.
What years is your XJ? Reason I ask is that the 00-01 are a bit finicky on which blocks can be used.Exos wrote:Anyone?
Block : got it (93)
Have you priced these out yet? When I purchased my pistons the .060s were quite a bit more than the .030 KB944sPistons : need KB944 0,060 oversize
up to you reallycrankshaft spacer : 1 cm (from old pulley?) or cut crank 1 cm (done, crank cut)
one should come with your gasket setcrank rear main seal, oil pan seal : need
The 258 main bearings that came with your crank will not work with your 4.0L block. You need to get teh correct sized 4.0L main bearings. Also, you may want to notch the rod bearing shell for the oil hole. See in my build.rod and main bearings : with crank
I have ran the 232-4 and the 231-4 and liked both. I would go with the 231-4 but make sure your valve springs can handle the lift on either cam.camshaft + bearings : need (comp 232-4?)
You won't find the fel pro .043" at least I couldn't. Get the MP one of the Victor Reinz... but there is a new part number for the VR.. look for a tread called "gasket suprise" for the gasket set part number with the VR MLS .043" gaskethead gasket : need Mopar Performance P4529242 / Victor Reinz Dana 5713----0.043" or Fel-Pro 9076PT----0.043"
Go with a cloyes dbl roller or JP performance.timing gear and chain : reuse if good? Or kit with cam
oil pump: reuse
I wouldn't reuse the old oil pump
I wouldn't us the comp kit ones.. I feel as their pressures are too high even at their correct installed height. Find some Mopar Performance valve springsvalve springs, retainers and locks : need some (comp kit?)
Should come with the gasket setvalve stem seals : need some (comp kit?)
YTs are great, but if you are spending the money on rollers get the adjustable Harland Sharp's and you won't have to worry about push rod length.. or adjustable Yella Terras if you can find themrockers : from block if good, Yella Terra roller rockers if I win lottery. (Crower stud mounted an option?)
For that money I would get an FTC instead. Also, you may want to get a wideband afr gauge.piggy-back fuel controller : http://www.alamomotorsports.com/apexi/safc.html#safcneo
For parts I used mostly Falcon on ebay.
- Exos
SilverXJ wrote:What years is your XJ? Reason I ask is that the 00-01 are a bit finicky on which blocks can be used.Exos wrote:Anyone?
Block : got it (93)
It's a 98
No price yet, but I'm in Canada, so it sure will be pricey
I got the 4.0 mains swapped in
oil pump: reuse
I wouldn't reuse the old oil pump Why? Are you suggesting an HV pump?I wouldn't us the comp kit ones.. I feel as their pressures are too high even at their correct installed height. Find some Mopar Performance valve springsvalve springs, retainers and locks : need some (comp kit?)
For that money I would get an FTC instead. Also, you may want to get a wideband afr gauge. What's an FTC?piggy-back fuel controller : http://www.alamomotorsports.com/apexi/safc.html#safcneo
- Exos
Also, I'm a bit confused, as my '98 XJ FSM says this about pushrods : 9.640-9.660" So what's the truth? I guess I'll measure my old ones tomorrow...
The comp cam springs, retainers, and locks won't work with the stock 8mm round groove valves.
- Exos
SilverXJ, I have three pending questions :
- -My '98 XJ FSM says this about pushrods : Push Rod Length . . . . . . . .244.856 to 245.364 mm
(9.640 to 9.660 in.) So what's the truth?
-You said you wouldn't use the old oil pump, are you suggesting/using a HV pump, like Melling?
-You mentionned "FTC" about fuel control, what is it, I did not find anything?
The push rod length in the FSM is an acceptable range of pushrod length. I don't know how much a factory push rod would be off from the next, but it will fall in that range.
I wouldn't recommend a HV pump. Just a new regular pump. I have never heard of a HV pump being needed in these engines and if it is not then it is a waste of power and extra stain on the cam gear to have to turn it.
An FTC (Fuel/Timing Calibrator) is a piggy back computer by Split Second that allows you to adjust the the fuel curve in open loop.
http://www.splitsec.com/products/ftc1/ftc1ds.htm
- Exos
Thanks for the reply. One more and I leave you alone for a while...
Hesco sells HD valve springs (HESSPRSS6). Are these the same as Mopar perf.? They mention that machining of the head will be required to achieve correct installed height. Do you have to have some machining done with Mopar perf. springs too?
I don't know what springs the Hesco units are, but other springs can be made to work as well. As far as machining for the MP springs, most people don't. I did because they are about 113# seat pressure at installed height (1.64"). I wanted 100#, so I have the seats machined a bit to get them to 100#.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
