i read that with heavy spring rates and high lift cams, that the stock stamped steel rockers can crack and bend? and also the push rods too. i am using a mopar performance cam with over .400 lift. and mopar 5.9 springs, keepers, retainers. Any info?
thanks guys, bryan
rockers
shockcocker04
Re: rockers
I run the mopar 30ab cam(.045" lift) w/ the 5249464 springs and associated retainers and keepers. I bought sealed power factory replacement rockers and their 9.602" pushrods. I'm at 10K now and all seems fine. I will check out the valvetrain when I replace the cork gasket with a rubber one.
shockcocker04
Re: rockers
that is exactly what i have now
ok well i guess if they were going to fail then they would of already.
thanks alot, bryan
thanks alot, bryan
- Mgardiner1
Re: rockers
I'm running same cam/spring combo, except i'm using yella terra 1.7 roller rockers. I've only got 2K on the engine so far, and all is good up to this point
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
