http://www.jeepforum.com/forum/showthread.php?t=502977 Sorry about that, The aging process does strange things sometimes.
bored out throttlebody?
- John
Sighman
Re: bored out throttlebody?
Thanks everyone, I did smooth them out but I didn't bevel them to the extent of the pictures. I'll pull it this weekend and see what happens. Once again thanks!!
rradford9
- Stroker Displacement: 4.5l
Be sure to let us know if that fixes it. I'm battling a similar whistle out of my 62 mm bored TB. I very lightly touched up the sharp edges with my dremmel, but didn't take off anywhere near the amount from the write-up. I still have the whistle, so I'm looking for a solution...
4.5L Simple Stroker
* 4.2L crank & rods
* H802CP pistons (18cc dish)
* 9.57:1 SCR / 8.28:1 DCR
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* 2.5" Magnaflow cat and Flowmaster 50
* JBA Header
* 4.2L crank & rods
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* JBA Header
Sighman
That did indeed fix it. I didn't go deep enough the first time and it still whistled slightly. Took it back off and went deeper and the whistle is completely gone now!
- John
Good man. I get a failing grade and you get rid of the whistle.
- Dirtweazle
Just an FYI on this thread:
If you bore to 60mm there is no need for a new flutterby....... Works fine on mine.
Troy "WeaZle" McCarty
2K XJ 4.6 (Go Slow)
88 Raceco Class 10 2175cc (Go Fast)
07 Avia 6877 size 12 (Go Pedestrian)
2K XJ 4.6 (Go Slow)
rradford9
Beveling the port eliminated my whistle too. Thanks for posting the writeup! I ended up beveling the top port above the butterfly a little bit too b/c I blew compressed air over it to clean off any metal flakes and got a slight whistle.
4.5L Simple Stroker
* 4.2L crank & rods
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* JBA Header
* 4.2L crank & rods
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* JBA Header
